P0204
Old Jan 11, 2008 | 05:29 PM
projekt_shocker's Avatar
P0204
I have this code popped up a couple days ago...
my car is running fine and all but it idles, runs like a boxer motor... thought it was the coils and plugs so I changed that and that didnt work out... this was before i went to autozone to get my codes pulled up.
so after the problem is still there, i went to autozone and got my codes pulled and i got 2 codes... a P0139 and a P0204.
I believe the P0204 is a malfunction with just the injector right? and I know its in cylinder number four... is that located at the far right side of the motor where the coil pack is in?
Took out the injectors, clean the outside out from dirt and debris... and tested it with a voltmeter. it all shows close to spec... 4 ohms each... (2-3 ohms is standard). I dont know what to do next now...pretty much im stumped and I am thinking about switching the cylinder #4 injector to like a #3 spot swap it around and see how it runs... if it has a SES i will again take it to autozone and check on the issue... if it still shows a p0204 then i guess i found the culprit of the issue...which is the injector harness.... if its a p0203... then i am getting new injectors...
if you think there is any other (better) alternative to decipher this problem out... let me know. I am down for some ideas here.
Old Jan 11, 2008 | 05:40 PM
inco9nito99's Avatar
Cylinder #4 is farthest away from the timing belt, and yes p0204 is indeed injector #4 malfunction. p0139 is rear o2 sensor malfunction; do you have a anti-fouler on the rear o2 sensor (if you're using a testpipe?)..
Old Jan 11, 2008 | 05:46 PM
using a welded test pipe and i dont have that 02 cheat mod.
i am going to experience with it by swapping injector #4 (cylinder #4) with injector #3 (cylinder #3). That I would know for a fact that if a code pops up again... i can actually pin point which one to fix... either replacing the injectors or the harness.
I will keep everyone posted on my fix.
Old Jan 11, 2008 | 06:05 PM
ok now im really confused.... i just saw this from the evo service manual.
so is it the 2nd one from the left now?
Old Jan 11, 2008 | 06:44 PM
never mind i got it now. going to swap injectors and see what happens tommorow...
Old Jan 12, 2008 | 05:43 PM
well had a couple views in this topic but no one replies back... well i found the issue of the problem to this hopefully... if you guys have some experience about this problem i like to hear your solution to this...
https://www.evolutionm.net/forums/sh...08#post5147908
^^ link to the new topic i started up in the evo advance section.
Enjoi926
May 31, 2017 06:47 PM
Biggiesacks
Oct 13, 2016 02:37 PM
STIU2SLO
Jun 19, 2016 07:40 PM
TurboKushGS-T
Lancer Troubleshooting
Apr 9, 2015 08:31 PM
francisr362
Mar 18, 2010 12:57 PM
