CEL P0202. Pls help!
Old Feb 21, 2009 | 08:24 PM
francisr362's Avatar
Hey guys hows it going? I have a 03 Evo 8, I was driving this morning to go to work and when i came to the stop light. CEL pops on and code was for # 2 Cylinder Misfire and a DTC P0202 Inj. 2 Circuit Malfunction.
Has anyone here ever gotten this code and wut the problem was?
Im getting voltage in my # 2 Inj. Connector and the Inj. Ohms out like the rest of them at 2.4 Ohms.
I also tried to swap Coils from 2 to 4 just to see if its spark related but its still in that Cylinder.
Thanks
Francis
Old Feb 22, 2009 | 06:44 AM
gsrboi80's Avatar
Have you pulled that plug??? Maybe its not tight or maybe its shot which can be an indication of a more serious issue
Old Feb 22, 2009 | 07:35 AM
lacrosseks29's Avatar
your right try what he said
Old Feb 22, 2009 | 06:51 PM
Thanks for responding guys.. Yeah sorry i forgot to mention that.. I did pull the plugs and even swaped plug 2 to plug 3 to see if the problem would go to the Number 3 cylinder.. Didnt happen.
Im still going to be replacing the plugs tho since they dont look too good. but yeah im going to work on it tomorrow when i get to work in the morning so i hope i find out what the problem is.
Old Feb 23, 2009 | 03:45 PM
K Well Im pretty sure i figured it out but just waiting for the part to come from Mitsu to Verify tomorrow. Ill keep u guys updated!
Francis
Old Feb 24, 2009 | 08:33 PM
zbestevors's Avatar
most of the time you would only swap plugs and coils if you have a cycinder misfire code. i would use a voltmeter etc. to check the trigger side of the injector harness. and or swap #1 and #2 injectors and erase the code. if the code comes back on for a different cylinder than that injector is the fault. replacing parts can get expinsive.
Old Feb 25, 2009 | 09:14 PM
Thanks for the Input.. Yeah i did the diagnosis already and ordered part that I found was Bad. Installed new part.
RUNS AWESOME! NO more Misfires even under Boost!
Thanks
Old Mar 18, 2010 | 12:57 PM
jdmblue's Avatar
what did you find was the issue here for i am having the same problem.
tarheelsoldier
Mar 22, 2015 08:54 AM
4RETECH
Jun 17, 2012 07:05 PM
titaniumkingpin
16
Aug 22, 2007 10:34 PM
CBRD
Sep 30, 2005 09:05 AM
pumpdog720
Sep 7, 2005 07:05 PM
