P304 CEL 4th Cylinder Misfire
It can be a plug or an injector. The coil shares itself with number 2 cylinder so it would cause a misfire code for that one also. Try the plug first, even if it looks ok you should replace it. If the code comes back,try and swap injectors with the number 3 cylinder and erase the codes once again. If the code comes back and it is for #3 cylinder then you know the injector is the problem. Good luck.
Gil-superz
Gil-superz
Originally Posted by titaniumkingpin
update-
today i threw two P300 codes.
what could that mean? yesterday i throw a 4th cylinder misfire and now today i get two P300 codes.
im changing my plugs out today.
thanks superz, im going to try swapping injectors also. any other ideas?
Also - spark plugs are comething I would check
If the plugs are bad - again check your a/f ratio as when its off it can foul your plugs
Best of luck sorting it out
possible bad coil pack???
Anyway, change your plugs to start off with.. Its cheap insurance.
Didn't I recommend this already in a different post?
Ok this may be an old thread but I got the 4th cyl misfire after driving home on the 11th coming home from my tune at Buschur, went right to autozone after I got off the freeway, plugs looked good, got a new set of BPR8ES at .26 same as when I was tuned just hours prior, reset the ecu and car idles very rough...... any ideas?!?!? Sorry for the late post I went out of town right after I got back! any ideas?!?!?
i remember when i was going through these codes daily!!
I can't pinpoint what the problem was but now its gone.
I changed plugs and was still getting both these codes. Then after i got reflashed again by a different tuner, my car is running solid without any codes.
I'm not saying it was the tune or the plugs.... im just not sure.
Good Luck
Good Luck
