Connecting subwoofer
I am figuring out a way to get more power out of my subwoofer.
I currently have a 12" Infinity Reference Sub and an 800w Infinity Reference Amp.
The amp is 6 channel and I have 4 speakers and the sub hooked to it. I am bridging the 2 channels to 1 to just run the 1 subwoofer.
But the thing is the sub is a dual voice coil. The amp can run a 4ohm sub when bridged which I am doing and the sub is also 4 ohm, but since it is DVC, should I run it in a parallel wiring to lower the impedance down to 2 ohm, or does it not matter since the amp can power at 4 ohm load?
Which is what I am asking since it can hold a 4ohm would it matter if I run the sub at 4 ohm or 2ohm? Would 2 ohm be any better?
It all depends on if that amp is 2 ohm stable. Which, when it is bridged you are running the sub in series at 8 ohms and the amp has the max power at 4 ohms.
So you would be best to drive the sub at 2 ohm mono, the only problem is that the infinity amp probably isnt stable at 2 ohm. I would get a mono sub amp, that is stable to 2 ohm. They are pretty easy to find..
Originally Posted by logikalliquid
If its a dual voice coil sub and it it wired to 4ohms now, then if you change the wiring it will be 1ohm not 2.
Originally Posted by marlboroman9006
if it is a dual voice coil at 4 ohms each and you wire it in parallel, the load will be 2 ohms.
With 1sub:
dual 2ohm VCs = final load of 1 or 4ohm
dual 4ohm VCs = final load of 2 or 8ohm
just to clear it all up
ToddRhodes
11
Jun 12, 2013 12:12 PM
ImJoey
Jun 27, 2007 04:05 PM
gbwaacha
Apr 19, 2004 10:28 AM
