EVO VIII Boost Problems
Old Jan 12, 2008 | 06:35 PM
birdxa's Avatar
I recently replaced my manifold and 02 housing. a few weeks later I noticed an exhaust leak at the 02 housing, so I ripped it all back apart and replaced the gasket. Now my Evo shows about 2 pounds of boost and it feels like the turbo is falling on its face at higher throttle. Any Ideas? thanks for your time!
Old Jan 12, 2008 | 07:15 PM
partyboy1122's Avatar
Check for boost leaks
Old Jan 12, 2008 | 07:16 PM
VenomEVO8's Avatar
ya if you can't find leaks maybe you fixed a problem you didnt know you had
Old Jan 12, 2008 | 07:25 PM
eponti's Avatar
Are you tuned for it?
Old Jan 12, 2008 | 10:03 PM
birdxa's Avatar
I haven't yet tuned it , I did a boost leak test and there are no leaks. Still max boost of 2 psi I have no Idea what it could be...
Old Jan 13, 2008 | 12:54 AM
KcEvil8's Avatar
make sure the waste gate actuator rod is still connected to the flapper. maybe you accidentally knock it loose when you install the o2 housing.
Old Jan 13, 2008 | 06:33 AM
birdxa's Avatar
the rod is still connected, I feel like pulling my hair out lol...
Old Jan 13, 2008 | 07:23 AM
cfdfireman1's Avatar
How much preload do you have on the WGA?
Old Jan 13, 2008 | 07:36 AM
birdxa's Avatar
to be honest with you I have no Idea, if it helps, everything is stock except for the exhaust. Im a former honda guy so this whole boost / Mitsu stuff is all new to me. lol
Old Jan 13, 2008 | 07:42 AM
EVO316's Avatar
you may have to take everything apart, re-check and check, then put it all back together. take your time and then test again. It may be a pain but that's what I would do.
Old Jan 13, 2008 | 07:44 AM
Check to see if you have any shaft play on the turbo it self.
Make sure it spins freely also
Old Jan 13, 2008 | 07:51 AM
crimes's Avatar
how does it feel on the road? sometimes it helps to check the simplest things first, I know it probably sounds stupid but have you checked the guage?
Old Jan 13, 2008 | 07:55 AM
crimes's Avatar
Have you still got the stock boost control solenoid?
Old Jan 13, 2008 | 10:02 AM
birdxa's Avatar
yea its stock, on the road it has no power. Im going to dig back into it tonight.
Old Feb 6, 2008 | 03:10 AM
birdxa's Avatar
ok so I finally found time to dig back into it, the turbo has very little shaft play, spins freely, the wastegate is fine and functions properly, the boost selenoid I got rid of and installed a Profec B II, Exhaust gaskets appear to be fine. Turbine fins are fine aswell. Put it all back together still have same problem 2 psi and it continues to fall on its face. I have no idea what could be wrong with it.
skochur
Northeast Region
May 15, 2011 06:54 AM
dinok
Sep 6, 2010 06:32 PM
Srt-4 Turbo 7
ExtremeTurboSystems.com – WA
Mar 17, 2010 11:18 AM
pwdrtoastman
Feb 15, 2010 11:09 PM
RnR Racing
23
Sep 30, 2003 11:48 AM
