finding dumptube ??
Old Jan 15, 2008 | 07:00 PM
turbodreamz21's Avatar
finding dumptube ??
hey guys i tried looking up but no luck
anyone know where i can buy a dumptube for my gt3076r setup that i am about to do?
Old Jan 16, 2008 | 02:19 AM
Dapper Dan's Avatar
buy the flange and weld one up.....
Old Jan 16, 2008 | 04:53 AM
sabastian458's Avatar
Yeah i had the same problem. I ended up fabbing up my own pipe. Looks like butt, but it does the job.
Old Jan 16, 2008 | 09:33 AM
James@DSR's Avatar
You only get a dumptube if you buy a turbo kit and it comes with it or if I recall you can buy one from Full Race if you use there twin scroll manifold w/wastegate cause its the same routing. You pretty much need to fabricate one its really, really easy just send it straight to the floor and don't forget to wrap it or make a whole in your undetray or splitter with a heatshield around it and send it through that. Wrapping it will def help a little in under hood temps wise
James
Old Jan 16, 2008 | 11:49 AM
im goign to be running a DNP manifold and it comes already with a 44mm wastegate
so i dont need the wastegate im jus looking for the dumptube so you guys say i shoudl just fabricate one ? it owuld be easier
Old Jan 16, 2008 | 12:18 PM
that is what we are talking about, making the tube from the outlet of the 44 to the bottom of the car. it isnt hard to do.
Old Jan 16, 2008 | 12:33 PM
if i was to make the tube to that shoudl i also make a opening in the Dp shoudl i run the dumptube into the downpipe or just have the open dumptube?
i heard ppl saying ss dumptube any idea wat that is or where ot buy one?
Old Jan 26, 2008 | 06:01 PM
kaonashi's Avatar
full race makes a 44mm dumptube or ebay but you might have to do a tad bit of welding
Old Jan 26, 2008 | 06:13 PM
Jameson_IXMR's Avatar
Dump to the atmosphere, not the downpipe, that creates unwanted turbulance.
Old Jan 28, 2008 | 06:48 AM
kaonashi's Avatar
well like i said full race makes a 44mm dump tube that is VTA, and it comes with the vband clamp for it. good thing about the vband one's you can swivel them to the right position.
Old Jan 28, 2008 | 01:21 PM
dsmjeffro's Avatar
punishment racing makes one
there site iswww.punishment-racing.com
good luck
Old Jan 30, 2008 | 05:04 AM
EvoTech's Avatar
Pick up some DEI heat wrap for the sensors and starter wires that will be in the area that you are dumping.
hermesevo8
Dec 16, 2016 12:00 AM
YFZracer32
Oct 4, 2016 07:47 PM
Howulikemyevo
Apr 4, 2016 06:21 AM
Howulikemyevo
11
Mar 28, 2016 05:03 AM
Tbtalon94
Feb 10, 2010 01:31 PM
