MBC only boosting 10-13 psi
Old Jan 16, 2008 | 09:41 PM
EgoBstr's Avatar
Would this be the result of me turning the mbc af far as it would go counterclockwise to the lowest boost setting? I have it ther until I can go to my tuner Friday. The directions from Hallman say that for this setting the car will boost at its stock setting and then only increase. Has anyone experienced lower than stock boost when turning the Hallman mbc to the lowest boost setting?
Old Jan 16, 2008 | 09:42 PM
W_evo8's Avatar
Originally Posted by Kdash106
also. make sure you use the hard spring that come with the BC
yep!
Old Jan 16, 2008 | 09:43 PM
Kdash106's Avatar
well like i said earlier, did u use the hard spring that you got with the MBC? and u used new line from the wastegate to BC?
Old Jan 16, 2008 | 09:44 PM
EvoBroMA's Avatar
there are two pills in the stock lines, so dont use the stock lines.
theres a pill at the turbo, and at the solenoid.
Old Jan 16, 2008 | 09:47 PM
EgoBstr's Avatar
It didnt come with any extra springs........was it supposed to? I did use a new line from teh wastegate to the BC.
Old Jan 16, 2008 | 09:48 PM
eponti's Avatar
I dont think it comes with a stiffer spring or at least mine didnt and its the same mbc.
Old Jan 16, 2008 | 09:50 PM
eponti's Avatar
Crank that sucker up clockwise and you will see more than 13 psi.Set it to 19 psi till you get tune.
Old Jan 16, 2008 | 09:52 PM
Celica2EVO's Avatar
it has your stiff spring in it already! The how you have it turned all the way off, the 12 pounds is just running wastegate pressure! Stock boost is 20 psi and you can take it to 22 safely with as rich s the stock AFRs are. So you should be ok to turn it up to at least 17-18 psi. As of now you are only running at wastegate!
Old Jan 16, 2008 | 09:53 PM
EgoBstr's Avatar
does the bc have to be mounted vertically...I mounted mine horizontal? Other than that I cant think of anything. I have checked and rechecked the setup 4 times tonight. It is exactly as the diagram shows posted earlier and I used new proper lines. What is going on?
Old Jan 16, 2008 | 09:56 PM
EgoBstr's Avatar
O great, so it sounds like I had it hooked up right all along, I just need to turn the boost up some? If this is the case the Hallman directions are misleading.
So on all of you guys setups out there if you turn the boost all the way down it will read 12 psi as well? I was going nuts trying to figure out what I hooked up wrong.
Old Jan 16, 2008 | 10:00 PM
Kdash106's Avatar
well mine come with a hard and soft spring, when my BC is turned all the way down, it was at 10psi. but u can try to turn it up more.
Old Jan 16, 2008 | 10:08 PM
EgoBstr's Avatar
do i need to do something with the spring or just leave it as is and tunr the boost up to 18 psi?
Old Jan 16, 2008 | 10:12 PM
Kdash106's Avatar
well, if your BC didn't come with another spring, then just turn it up. don't go crazy on it, just turn half circle at a time.
Old Jan 16, 2008 | 10:14 PM
Celica2EVO's Avatar
The spring is the stiff one that you want! 10 psi is the evo 8 wasegate, 13 psi is the IX wastegate. I just swapped turbos is how I know this. It most likely is set-up correctly, I tore mine apart 5 times due to jackasses on here saying that one turn and ull blow your car up and Hallmans directions. It takes quite a bit of turning to get it to start moving. Start with 5 turns at a time untill you get close to 19 psi, and then just slowly change it untill you get the 19 psi. But it will take a while and it is just keep trying to get it right!
Old Jan 16, 2008 | 10:15 PM
Chamama's Avatar
You are running on wastegate pressure, which is exactly the boost you are seeing, not stock boost.
