Meth Injection Help
Old Jan 17, 2008 | 10:00 PM
uSmC_08's Avatar
Cool, thanks for the info guys....What about if I kept mods in sig and went with just cams, NO meth?
Would stock injectors do?
Sorry for the O.T.
Old Jan 17, 2008 | 10:08 PM
FullOutPwr's Avatar
Originally Posted by sparky
Maybe someone with a IX turbo can chime in.
I run an evo 9 on my VIII with licp/uicp/intake/cams/02 housing/3" TBE, 255 pump @ 22 psi my injector duties were 105% right about 6700 RPM
Old Jan 17, 2008 | 10:19 PM
Celica2EVO's Avatar
So with metha and my mod list my injectors are maxed out? Will they be ok with Meth tho? Below is my list. Thanks
Buschur Racing Deluxe Intercooler and Piping
Buschur Racing MAF Pipe and Filter Kit
Buschur Racing Mini Battery Kit
Walbro 255 fuel pump
Megan 02 Housing
NGK BR7EIX Plugs
1G Forge BOV
Megan SS Tubular Manifold
Snowperformance Methanol injection
VP 100% Methanol
Brian Crower 272 cams
Fidanza Cam Gears
EVO IX Turbo
Hallman Pro RX MBC
DC Sports Downpipe with Cat-delete
HKS Carbon TI Catback
Transmission Buschings
Shifter Bushings
Buschur Racing Stage 1 Transmission
Exedy Twin Plate HD Clutch
SS Clutch Line
FP IX Install Kit
Shep Stage 2 T-Case
Ralliart LSD
AMS Front Motor Mount
SS Radiator Hose
Gates Kevlar Belts
Old Jun 11, 2008 | 12:45 AM
DIDYSIS's Avatar
Injectors Go big or go home
Get bigger ones !!! They are not that expensive and will let you get the most out of everything you got there.
Old Jun 29, 2008 | 03:25 PM
EVIL MR's Avatar
Zeitronix & meth are best friends. You can get both from TTP and a loads of fail save.
Old Jun 29, 2008 | 03:30 PM
4WS Tuning's Avatar
He doesnt need injectors for a stock turbo when running meth. Won't help a single bit.
Cheers!
Old Jun 29, 2008 | 03:34 PM
jhanksevo's Avatar
+1 but I would suggest running BPR8es spark plugs one step colder than stock
Old Sep 4, 2008 | 10:10 PM
EvoInvidia's Avatar
Well what if you are runny an evo 9 with cams, meth, fpgreen, and other basic bolt ons, will you need bigger injectors then and if so, what size?
Old Sep 19, 2008 | 10:42 AM
TKEVO's Avatar
Veteran: Air Force
780cc would work fine.
Night12000
Apr 22, 2016 02:56 PM
TTOPPOUZI
14
Aug 12, 2008 06:57 PM
slikdzigns
Jun 1, 2008 10:39 PM
strokedt67
20
Sep 17, 2007 09:30 PM
Nood1es
Sep 15, 2007 12:46 AM
