problem after cam install
Old Sep 13, 2008 | 05:17 PM
vvhiteix's Avatar
after i installed my cams with my friend that is a tech after the install my vac is down to around 11 and the idle is very rough and lean im trying to determine if my timing went off or a simple modification to my tune will fix the rough idle.. the cars drives easy just low rpm it struggles.
Old Sep 13, 2008 | 05:22 PM
Duh Panda's Avatar
need a retune buddy
Old Sep 13, 2008 | 06:40 PM
vvhiteix's Avatar
yea...i know that but i also threw a code...didnt pull it yet though im figuring its a misfire or...something of that nature because i know my timing isnt off
fyi i installed the cosworth m2 cams
Old Sep 13, 2008 | 07:38 PM
vvhiteix's Avatar
bump
Old Sep 13, 2008 | 07:41 PM
VIPGarage's Avatar
It's worth the time to double check the timing just in case. I've had cars towed over for similar reasons so it's worth your time to just double check your marks.
It's most likely just the car reacting to the new cams. You'll notice a drop in vac and a lopier idle.
Old Sep 13, 2008 | 07:47 PM
Chabada15's Avatar
come on dude, after any bigger cam install your vacuum will go down...your talking about a big cam with the M2, i lost 5psi of vacuum, you lost 11g which is about 5psi, either way no big deal, second with a cam that has a longer duration you gain top end...well sorry to tell ya bro you cant have the best of both worlds, you sacrifice bottom end, although a good tune with sum timing added down low you shouldnt have a problem, and a tune will also fix your idle since your probly idling around 10* and should be around 5* after the tune for your cams...anymore questions PM me
Old Sep 13, 2008 | 09:42 PM
vvhiteix's Avatar
yea i logged my idle im around 12 ish sometimes higher sometimes lower...depending what rpm my car is at...its jumping around also...anywhere from 600rpm to about 1200rpm... its obviously because im not tuned for the cams but the code i will pull tomm morning and see what it is..
Old Sep 14, 2008 | 12:15 AM
Chabada15's Avatar
yea set your idle from 10-50 load and from like 500 - 1250 to 5* that should help...you may also need to scale your maf and/or injectors so try that
Old Sep 14, 2008 | 08:46 AM
vvhiteix's Avatar
im about to pull the code just waiting for my buddy to come over with his reader... i tried looking for a thread with the engine codes but could not find it can anyone help me out in finding that thread? i remember stubbling across it some time ago
Old Sep 14, 2008 | 09:08 AM
Chabada15's Avatar
just post it youll get an instant response more then likely its PO300 which is random/multiple cylinder misfire...it happens from the stumbling idle...and your idle will richen up when you run less timing at idle
Old Sep 14, 2008 | 10:48 AM
vvhiteix's Avatar
well i'll know soon...hopefully thats what it is
Old Sep 14, 2008 | 11:45 AM
EvoVIII808's Avatar
prob the misfire code, or the Lean Injection code. Those were the ones i got when i installed my HKS cams
Old Sep 14, 2008 | 12:53 PM
turbogst311's Avatar
it ended up being p0300. Multiple cylinder misfires. Theres also a loud rattle coming from the intake cam near top left cover of valve cover. vvhiteix is going to take the valve cover back off tonight and check it out. What can be causing this rattle noise from the intake cam? Everything was torqued.
Old Sep 14, 2008 | 02:06 PM
Chabada15's Avatar
dont bother bro..its your PCV...mine does the same thing nothings wrong dont waste your time...youve never had a cammed car before have you? lol ...not making fun just ask questions before jumping to take your car apart...anyone with cams can tell you that sumtimes the PCV or Pressure Control Valve which is on the top left of the valve cover just behind the oil cap will sumtimes make noise like a clicking rattling type noise
Old Sep 14, 2008 | 02:14 PM
papa_mario's Avatar
i am having the same problem with my buddy club 272's, causing the p0300. what fixes that?
