Shifting - Evo VIII - New Owner
(1) What are the best rpms to shift at for 2nd, 3rd, and 4th in an Evo VIII 2004?
(2) Does anyone know what the mph range is for each gear?
you shift your car at 4500, you are not even making peak power at 4500? Why would you shift that low?
I think the question at hand has you guys all confused. Shifting a 4500 for normal driving is understandable if not a little high actually. I shift on normal drivng at like 2500-3k. But when I am going down the track I pull the thing up to 7800 But then again I am not even close to being stock anymore. When I was stock I would never pull it past 7
yea, if you are going for top rpm, not normal driving, take it to where you feel comfortable. My 03 Evo VIII will do 82ish at the top of the RPM where i shift at about 7200. Have not checked 4th gear yet.
The evo viii has minor mods... hks intake, catback exhaust, and perrin short shifter. I have shifted between 4000 and 5000 rpms. I guess I just need to feel it out. I definitely don't want to get close to the redline.
What speeds have you guys hit at each gear?
The "best" shift points for normal driving are those which feel smooth for your own personal driving style and car. Learn to feel the car, you will know when you have found the shift points that work for you.
I don't think taking it to redline with minor mods would be much of a problem if you are in a hurry. Upper end of the powerband on a stocker kinda sucks anyway. My advice would be to take a little extra time when you shift making sure the clutch is fully disengaged. Not having this problem on previous cars, I found out the hard way on mine. I still have the original trans but it needs tlc until I can get it rebuilt.
Thanks for the advice guys. After spending sometime working her in, I discovered the following:
I stayed away from redlining and identified good shift points by identifying the rpm to which optimal acceleration was achieved. As expected, I observed that this varied based on gear.
Last edited by darkknight; Feb 4, 2008 at 05:21 PM. Reason: added "as expected" to indicate that my observations support my hypothesis
