T-Case fluids
Old Jan 20, 2008 | 10:04 PM
EVOLV3D's Avatar
T-Case fluids
is it absolutely a must to run the oem diaqueen in there, or can i use something else, i didnt really think about it til now but i already bought the fluids i got some castrol syntec its the same weight and everything and synthetic and if so can i at least run if for about a week or two without damaging my transfer case....also what about the tranny i got castrol syntec for that too
Old Jan 20, 2008 | 10:08 PM
bluebanana23's Avatar
just use what is proven. Better safe than sorry.
Old Jan 20, 2008 | 10:18 PM
EVOLV3D's Avatar
i would but i bought these when i started my clutch install and im broke, only 16 so cash flow is minimal!!! Im just wondering if this will be ok under normal driving conditions for about a week or two
Old Jan 20, 2008 | 10:25 PM
Kracka's Avatar
Is that Castrol synthetic a GL-4 or 5?
Old Jan 20, 2008 | 10:38 PM
EVOLV3D's Avatar
i believe it says api-gl5
Old Jan 20, 2008 | 11:33 PM
chaotichoax's Avatar
you have an MR and it is absolutely NECESSARY to use oem fluids
Transmission fluid –
Diaqueen Super Multi-Gear Oil 75W-85 (Part # - MZ313376)
Transfer Case and Rear Differential fluid –
Diaqueen LSD Gear Oil (Part # - MZ3775610)
Old Jan 23, 2008 | 05:32 PM
EVOLV3D's Avatar
so i cant run the castrol syntec for about a week or two?
Old Jan 23, 2008 | 07:07 PM
barneyb's Avatar
With a nice car like an MR, I'd walk before using the wrong lube. But, do what you have to do. I hope it doesn't cost you.
Old Jan 23, 2008 | 07:24 PM
RussellM's Avatar
Plat Vendor
Im partially, but I have to say use Diaqueen. Search...there are tons of reviews on different fluids.
Old Jan 23, 2008 | 08:28 PM
EVOLV3D's Avatar
i looked but couldnt really find anything on these fluids, i just need to know if these fluids will be good for about a week or two til i get the money for the mitsubishi fluids? See heres the thing, im in high school and need to get my car on the road by this coming monday and i dont know if ill have enough to get mitsubishi fluids from the dealer, does anyone know how much the dealer charges for them enough to do the transfer case and the transmission?
Old Jan 23, 2008 | 08:43 PM
do you have stock fluids in there now?
you'd be better off leaving them for another two weeks rather than putting in a non OEM fluid
the tranny fluid is where you really shouldn't mess with anything but OEM
Old Jan 23, 2008 | 08:53 PM
EVOLV3D's Avatar
sorry forgot to say that im doing a clutch install, and ive already bought these fluids at the parts store they had a book to look up what i needed and they said this would be good but i just need to know if this will hold up or if i need to call mitsubishi tomorrow and see what its going to cost me to get new fluids, would you have any idea what it might cost?
Old Jan 23, 2008 | 09:04 PM
EVOLV3D's Avatar
its a gl-5 75w90 synthetic gear oil
Old Jan 23, 2008 | 09:09 PM
Skywarp's Avatar
I wouldn't use any thing other than OEM fluid in the T/C (40 bucks if I remember correctly) even for just a week or two. As for the tranny, the 6 speed fluid isn't cheap. Like the earlier post said, better safe than sorry. Careful with parts store recommendations, half the time they know less than you do.
Old Jan 23, 2008 | 09:13 PM
EVOLV3D's Avatar
thats what i was thinking, well im going to take those fluids back and get some mitsubishi fluids
