my plans.. what do you think
Old Jan 28, 2008 | 02:30 PM
RevMoto's Avatar
Originally Posted by tmaxxman21
should i get the br3065 instead??
A green makes the same power as a 3076 on pump almost and make a **** load more torque and the spool is not even comparable. A br3065 is a great turbo. You will see low 400's easily on pump. If you only plan on running pump gas then no need to get a larger style turbo. You are just getting a laggy car without the power.
Old Jan 29, 2008 | 01:04 PM
tmaxxman21's Avatar
yeah ill probably get the 3065 then.. thanks guys
