WTF is up with this
Old Jan 29, 2008 | 09:21 AM
Buschur_TSI's Avatar
WTF is up with this
Ok this has happened a few times and it always happens 2-3 times in a row. I will be driving in 5th gear around 60-70mph and when I push the gas the car acts like it is missing. It has no power and it shakes like crazy. Then it acts fine then repeats itself maybe a few min later, then all is well for say a week or 2. It does not happen everytime I drive. As a matter of fact it started about 3 weeks ago then it did it again yesterday. It did it 3 times with in say 45 min then not once again. Both times were on long drives.
Old Jan 29, 2008 | 09:23 AM
evoterp's Avatar
it looks like you got the infamous tranny harmonics P0300 issue. do a search on it. there are a lot of people (myself included) that have this problem. i'm guessing you have a higher mileage evo?
Old Jan 29, 2008 | 09:24 AM
C6C6CH3vo's Avatar
Could be one of 50 things depending on the mods and the most recent one prior to this happening
Old Jan 29, 2008 | 09:29 AM
evo8fl's Avatar
+1, i used to have the same problem good luck with that if u don't have a warranty
Old Jan 29, 2008 | 10:31 AM
C6C6CH3vo's Avatar
For some reason my car doesn't have the po300. It has 60,000 miles and is an 04
It would be more beneficial to datalog the problem and show a list of modifications
Old Jan 29, 2008 | 10:38 AM
TTP Engineering's Avatar
p0300
5th gear is loose, causing a rattle.
Old Jan 29, 2008 | 11:39 AM
Well I know I have that damn P0300 code, buschur said it would be from my twin disk clutch. I have hard intercooler pipes,exhaust,cams,fuel pump and a reflash. The Reflash has been done for months and it never happened till a few weeks ago. My car has a warranty on it although it does have 71,000 miles on it.
Old Jan 29, 2008 | 02:20 PM
evoterp's Avatar
Yeah mine progressively worse after my ACT clutch install at est?56k clutch install. now my 5th gear has a rhythmic sound most audible between 55-69 mph. at the early stages it wasn't noticeable, but after 20k miles later, now is very audible. It's to the point that once I reach 70 in 5th i misfire everytime I press the gas. 5th gear just wears due to the gearing (sort of like a bicycle: pedal gear <the biggest >rotating the smallest 5th gr <rear wheel> at least that's how i made sense of it) Every one revolution by pedaling, equals 3 rotations on the rear wheel (5th gr) . I've also read that the input shaft develops play after high mileage which seems helps to trigger the p0300.
Old Jan 29, 2008 | 06:52 PM
So what you are sayingn is I should have the warranty company pay dan buschur to rebuild it
Old Jan 29, 2008 | 07:16 PM
James@DSR's Avatar
Originally Posted by TTP Engineering
p0300
+1 Definately it happened to one of my friends evos not too long ago
James
Old Jan 29, 2008 | 07:28 PM
wickdaddy's Avatar
what warranty do you have that covers the tranny after your IC pipes, exhaust, cams, fuel pump, and reflash mods in addition to 71k??
I think we all need to pick up this warranty
Old Jan 29, 2008 | 08:53 PM
All that has to happen is for a repair faclity to say the part(s) need replaced. I just has a new control arm and a rear axle replaced.
Old Jan 29, 2008 | 09:00 PM
h.funk's Avatar
Clutch and Trannys are not going to be replaced under warranty
Old Jan 29, 2008 | 09:20 PM
why is that? It said bumper to bumper. I was told that they would replace the motor if it blew
Old Jan 29, 2008 | 09:25 PM
EVOlution561's Avatar
Does this p0300 happen at anytime or when the mileage gets higher?
