WTF is up with this
Old Jan 29, 2008 | 09:27 PM
h.funk's Avatar
Clutch is considered "normal ware" and once you replace the clutch once with a aftermarket one then the tranny is out of warranty
Old Jan 30, 2008 | 02:14 AM
Buschur_TSI's Avatar
and they will know there is an aftermarket one how?
Old Jan 30, 2008 | 06:15 AM
evoterp's Avatar
Originally Posted by Buschur_TSI
So what you are sayingn is I should have the warranty company pay dan buschur to rebuild it
Well it's worth a try. But as most people have mentioned likely will not be covered in bumper to bumper. this is a wear item, but if they say they will cover give it a shot. I think I've read there was an instance where the dealership actually repaired an input shaft and 5th gear to fix this specific problem.
Good Luck! Let us know how it goes.
Old Jan 30, 2008 | 06:26 AM
evoterp's Avatar
Originally Posted by EVOlution561
Does this p0300 happen at anytime or when the mileage gets higher?
Seems like when the evo sees higher mileage people encounter the rhythmic vibration in 5th at certain speeds.
The p0300 is just triggered when the tranny harmonics trigger the sensor. And this is more likely to happen when cruising in 5th at a certain speed when 5th gear and input shaft or both worn in.
Old Jan 30, 2008 | 06:31 AM
Evo11V's Avatar
Veteran: Army
I had a problem like you described. Does it happen under boost only? Might be something as simple as your plugs. I had this problem and figured out it was my plugs, changed them and the problem went away.
Not saying this is the problem its hard to say but worth a try for a few $$ and 15 min of your time
Old Jan 30, 2008 | 09:12 AM
Yeah I actually changed the plugs becasue it was falling on it's face at anything over 17 psi. This seems to be different
Old Jan 30, 2008 | 11:36 AM
Well the warranty said that they will cover the cost of parts and labor for anything that goes wrong. So I am going to take the car to buschurs and if Daniel says it's the trans it's getting a bushwacker.
Old Feb 4, 2008 | 06:25 PM
mt057's Avatar
I can cause the code by giving it full throttle in 4th then coasting (sometimes randomly while crusing in 5th). When this happens on my 03 it causes my afr go to 18/1 and higher. It will return to normal afr after I depress the clutch or punch the gas, but shutters until then. I will log it tomorrow. Everyone keeps telling me to change my pump
Old Feb 5, 2008 | 11:30 AM
EvO9 PiPER's Avatar
well the P0300 came up for me when i put the spec twin disc clutch in!! when im in 5th going 60-70 and i let up off the gas you hear that harmonics sound coming from tranny, and it triggers the light!! they make a smart chip im trying to find that you put in your OBD 2 that resets it has you drive, without using a code reader? anyone heard of that??
Old Feb 5, 2008 | 11:49 AM
evohang's Avatar
Yup There is a code reader that clears it while you are driving so its not so annoying. A buddy of mine that owns mievo.net has it on his 03 and it works for him. I also have a 03 and also have the p-0300 code and yes i will soon have the code reader so i can travel from places to places without having the p-0300 code that feels like im hitting a brick wall and not going anywhere. Anyways Good luck to anyone and everyone who has a 03.
Old Feb 5, 2008 | 01:08 PM
wickdaddy's Avatar
Yes I do the same.. CEL pops on, pull the reader from the glove compartment and attach it. Make sure it's just the P0300 or the P0128 and nothing else, and it clears the code no more CEL and no more throttling from the ecu
jman49127
Lancer Troubleshooting
Feb 17, 2017 07:22 AM
Indianbrandon
Dec 28, 2012 01:20 AM
nekkidlad
Oct 31, 2011 05:16 AM
raiceboi697
Feb 14, 2010 01:30 PM
Clutchdc5
12
Dec 8, 2006 12:46 PM
