Arp Head Studs
Old Jan 31, 2008 | 02:04 PM
cssaddictm4's Avatar
The one by one method worked fine for my GT3076R setup @ 30psi/480whp. The only thing about removing the head is that I don't like playing with the timing.
Old Jan 31, 2008 | 02:43 PM
TKEVO's Avatar
Veteran: Air Force
Like they told me. If you are going 35r, change studs. Remove the head and do it the right way the 1st time
Old Jan 31, 2008 | 03:24 PM
lemmonhead's Avatar
stock is good even for 24-25psi. Hence why stock boost limit is set at 25psi
Originally Posted by xiaoni420
But yes, Kevin has a great question for you, why are you installing head studs? Unless you plan on changing your setup in the near future or plan on boosting much more than 22psi, you will be fine with the stock studs.
Sheasta
Oct 29, 2015 05:00 PM
EVO 4 life
Oct 26, 2015 08:11 PM
Sideck
Jul 4, 2015 04:24 PM
wacboyjulian
Oct 3, 2014 11:53 AM
Royer
Lancer Engine Tech
May 22, 2011 10:45 PM
