Check Enginge Light
Old Jul 25, 2003 | 02:16 PM
TaiwanEvo's Avatar
Check Enginge Light
Anyway to get ride of the check engine light from the TEST PIPES? besides the UR pipe..
Old Jul 25, 2003 | 02:36 PM
Mad_SB's Avatar
don't know for sure about the evo, but I would assume the reason for the cel is that the up and downstream o2 sensors are giving abou the same reading.
For the headers I put on my contour (yeah i know) you had to have mil eliminators which would basically cause the o2 sensor reading to vary enough and adjust the voltage enough to convence the ecu that the cat is still in place.
If you go to www.contour.org and search for mil eliminator you should come across some DIY instructions on how to build one. They plug in inline with the o2 sensor and only cost a few dollars to make.
Or, you could wait for a vendor to make them for the evo.
Old Jul 25, 2003 | 02:52 PM
MrBubbler's Avatar
perrin offers a o2 sensor with ther test pipe maybe you could buy one from them? just the sensor = P
eliminator 429
May 12, 2016 11:52 AM
XxLaNcErGTSxX
10
Aug 10, 2009 02:57 AM
cfralliart
Mar 13, 2009 08:31 PM
evane
Aug 21, 2008 02:32 PM
mcbrown35
Lancer Aftermarket Forced Induction Tech
Feb 24, 2005 07:20 AM
