10.5 hotside?
Old Jan 31, 2008 | 03:59 PM
evotuner04's Avatar
15 Year MemberLikedLoved
10.5 hotside?
I just bought a 10.5 hotside with a 16g already bolted on it and a megan racing o2 housing bolted on it too, now my question is on the hotside there are 4 thread holes for bolts and on the one i got has 1 bolt already in one of the 4 holes, and im confused cause a install guide on this forum showed two bolts in the holes on the hotside so does anyone know if this is important that there's one there and not two? Or what am i looking at here
Old Jan 31, 2008 | 04:56 PM
sparky's Avatar
Is it a stud and not a bolt? You can just use that one installed stud and get 3 bolts for the 3 remaining threaded holes, I think. Get good bolts though. I think that they are grade 8.8(?).
Old Jan 31, 2008 | 05:07 PM
evotuner04's Avatar
yeah i guess it would be a stud now that i think of it, how should i go about getting the other ones and how do they install, ive never worked on this before
Old Jan 31, 2008 | 05:13 PM
Mulholland0132's Avatar
You can order them from the dealer...this way you know your using the right ones. Thats what I did. Their only a few bucks each.
Old Jan 31, 2008 | 05:22 PM
evotuner04's Avatar
okay that's good, are they gunna be bolts or studs?
Old Jan 31, 2008 | 07:14 PM
Aby@MIL.SPEC's Avatar
call san rafael mitsu,; a vendor on this forum, and get the right studs / hardware.
the oem turbo hardware is hardened for the high temperature's your engine/turbo will see.
DO NOT TRY TO REMOVE YOUR OLD STUDS FROM YOUR CURRENT TURBO....
if you fck up just 1 stud, it will cost you more to get the stud removed than buying new studs...
yeah, you can find the right sized studs/bolts from kragen, autozone, but they are not the quality.
get antisieze to go on all your threaded hardware when you make the swap.
Old Jan 31, 2008 | 07:19 PM
evotuner04's Avatar
okay what about the one the that's already in it? is that one fine as is?
Old Jan 31, 2008 | 07:22 PM
20Grockit's Avatar
just call the dealer. you cant go wrong there cuz theyre made for the high temp the engine outputs. i wouldnt recommend autozone or advanced auto for studs b/c they most likely wont hold up as well as the oem studs. good luck with your install man.
Old Jan 31, 2008 | 07:27 PM
JRB_EVO's Avatar
You can get the studs from FP, here is the link. I am about to buy a few ones myself for an upcoming project.
http://store.forcedperformance.net/m...ode=Acc-Gasket
Old Jan 31, 2008 | 07:33 PM
20Grockit's Avatar
oh yeah i didnt even think of that. they probably have ones as good or better than oem.
Old Jan 31, 2008 | 08:21 PM
evotuner04's Avatar
alright thanks guys appreciate the help, and idk is that one stud thats still in the hotside gunna matter? or just pick up the other 3?
Old Feb 1, 2008 | 11:00 AM
evotuner04's Avatar
anyone???
Old Apr 15, 2008 | 09:16 PM
evotuner04's Avatar
on the link below what else do i need to buy for my hotside bolt up to the exhaust mani? is it the "evo turbo outlet stud" and is that it or do i need any washers and nuts? sorry i feel dumb but havent worked on the turbo yet so its relatievley new
thanks guys
Old Apr 16, 2008 | 08:45 AM
evotuner04's Avatar
someone? lol a lil help
Old Apr 16, 2008 | 02:24 PM
evo150's Avatar
pm chris at jnztuning to verify these part numbers https://www.evolutionm.net/forums/members/15796-11secdsm.html he is who i ordered mine from
MN119783 (Bolt) x2
MN119784 (Stud) X1 (youll only need one if you already have one stud in the hotside)
MD132930 (Nut) x4
MD132933 (Washer) x4
