BR cast mani turbo kit with ETS fmic
Old Feb 2, 2008 | 01:06 AM
Nissan2Evo's Avatar
Seeing if anybody is running this combo. I'm about to purchase a BR 3065 cast mani kit for my IX and am using an ETS fmic with ETS lower I/C pipe. If anybody has this setup matched togethor could you shed some light on how fitment was? any custom work needed? or does it not match up at all? Any advice, info would be appreciated to help make this install straight forward as possible. Thanks.
Jorge
Old Feb 2, 2008 | 01:23 AM
4WS Tuning's Avatar
The licp will most likely need a little trimming.... no welding or anything. maybe a hack saw to cut off that 45 deg bend...
Old Feb 2, 2008 | 06:11 AM
CrackerJackToy's Avatar
ETS LICP will not work. I already contacted ETS about this, this week.
You'll need a custom licp, or to cut half the ETS pipe, & use the buschur half to mate with it.
GL
Old Feb 2, 2008 | 06:47 AM
20Grockit's Avatar
+1
Old Feb 2, 2008 | 07:09 AM
psphinx81's Avatar
its real easy to make the licp work, just cut it
Old Feb 2, 2008 | 07:25 AM
Nissan2Evo's Avatar
works for me....thanks a lot fellas
Old Feb 2, 2008 | 09:07 AM
Brian's Avatar
This thread may be of some assistance to you.
https://www.evolutionm.net/forums/sh...hlight=buschur
BR makes the parts you most likely need, but any fab shop should be able to help out.
Old Feb 2, 2008 | 07:42 PM
vwjeff's Avatar
GL
OOORRR he could sell the ETS set up and get Buschur
Old Feb 2, 2008 | 07:53 PM
psphinx81's Avatar
true.
cant go wrong with buschur, IMO i dont like mixing up setups
Old Feb 7, 2008 | 11:23 AM
ETS Michael's Avatar
Our new sub $3k tubular manifold turbo kit will fit perfectly with either ours or any other stock replacement LICP and require no cutting or modification. It also includes the intake system Sent you a PM Jorge!
EDIT: I wasn't sure if that was you or not Jorge R. so thanks again for the order . Sent you another PM!
Tom
Old Feb 7, 2008 | 05:48 PM
4WS Tuning's Avatar
yea but thatll end up costing more than just cutting the angle off..
That licp used isnt worth more than 100.... then he has to buy another for probably close to $200
I cut mine and worked well
