MR Transmission Swap
Old Feb 2, 2008 | 08:57 AM
Maximum404's Avatar
Veteran: Navy
After a fruitless search I am curious if anyone can tell me if a VIII 5spd can be mounted in a IX MR?
Old Feb 2, 2008 | 09:22 AM
dagreat1's Avatar
you can do it you'll just require some parts from a 5spd car. i don't know exactly what you'll need but its on here somewhere or somebody knows exactly. I think CBRD did this to there time attack car
Old Feb 2, 2008 | 09:52 AM
CBRD's Avatar
you need the shift cable brackets the mount on the trans, you need the cables themselves, and the shift box and center console (otherwise it hits inside)...
and you need to either cut the harness off of the gearbox you are swapping in, and solder the wires in, or buy the proper wiring harness.
its not a bad swap at all, about 1.5 hours more than doing a clutch by itself.
cb
aznx1nvazn
25
Jul 5, 2008 07:01 AM
czwhat
Dec 11, 2007 06:21 PM
bsantos
Jan 26, 2007 09:01 PM
Yaroslav
Nov 10, 2004 02:38 PM
mrcoolhandsome
Oct 27, 2004 08:23 PM
