Little help please PCV valve.
Old Feb 2, 2008 | 09:12 AM
DocMortal's Avatar
I was troubleshooting my ticking sound and found out the ticking is the pcv valve,my question is when you take it out in your hand and shake it does it rattle ?
My does and wondering if its normal.
I see springs and the check valve shaft and it it working properly by the instructions in the service manual.
I did I search and didnt find an answer I know theres alot of posts of ticking and im glad its just the valve.
Im temped to try a different style pcv valve.
Thx guys
Old Feb 2, 2008 | 11:54 AM
EvoooB's Avatar
dont know if this is going to help you any, but when i replaced mine i shook it at the parts counter and it rattled a little bit and it was brandy new. so im guessing thats normal other than that i cant really help you out
Old Feb 2, 2008 | 12:11 PM
DocMortal's Avatar
thx for the reply
PCV tapping noise is pretty loud under a low idle. Might just get a new one try it out.
Old Feb 2, 2008 | 05:18 PM
lemmonhead's Avatar
here is how to check the PCV valve, this is straight from the mitsubishi service manual.
1.Hold the positive crankcase ventilation (PCV) valve with the vacuum side down. Insert a thin rod, and using light pressure, depress the end of the PCV valve spring by 5 − 10 mm (0.2 − 0.3 inch). Release pressure on the rod to see if the PCV valve spring will lift the rod to its original position.
2.If the rod returns quickly to its original position, the PCV valve is OK. If the stick does
Old Feb 2, 2008 | 05:20 PM
lemmonhead's Avatar
since your at it here is out the check the PCV system
1.Remove the positive crankcase ventilation (PCV) valve from the rocker cover, then reconnect the PCV valve to the vacuum supply hose.
AK203692POSITIVE CRANKCASEVENTILATION VALVEAC
2.With the engine idling, put your finger on the open end of the PCV valve, and check for negative pressure (vacuum).
NOTE:
At this time, the plunger in the PCV valve should move back and forth as the open end is covered and uncovered.
3.If negative pressure is not felt, clean or replace the PCV valve. Inspect the vacuum supply hose and vacuum supply hose port for restriction or plugged condition.
TariqEvo
Jul 17, 2017 07:21 AM
aamoedo
Oct 28, 2016 09:22 AM
BlueEvo61106
Oct 30, 2008 09:50 AM
FiftyFive
17
Jan 5, 2008 12:07 PM
BluEVOIX
Apr 3, 2007 11:52 PM
