57trim 100oct pump
Old Feb 5, 2008 | 10:48 AM
V8HAHA's Avatar
400 on 92 is very possible on a dynojet im using 91 on 19psi with a mustang dyno and like I said before I ran 12.0@113 when I made 350whp on this dyno before. My 100oct tune i very safe didnt really hunt for hp with it just cleaned up the af and lill bit of knock we seen other then that the turbo done all the work could have mostlikely done 104oct some 32psi and some timing and would have seen another 20-25whp but wh bother im pushing it as it is for a stock motor 13,000 miles just wanted a mid 11sec car and im sure I have it
Old Feb 5, 2008 | 05:41 PM
SickSilverNLow's Avatar
Originally Posted by xiaoni420
Those numbers are from a dynojet. I can't remember his times...Monty??
11.9 at 119. With a better launch i should be in the 11.7s or so.
Old Feb 5, 2008 | 05:54 PM
kaonashi's Avatar
man im having 2nd thoughs about this, i ran 11.8@118 with the stock turbo on pump. Maybe i should have went bigger....
Old Feb 5, 2008 | 06:06 PM
StreetLegal66's Avatar
"AZ EVO IX MR" hit 11.75 on stock turbo with just bolt-on's and a tune back over a year ago (Oct 2006). His car only put down 350whp on the Mynes Mustang Dyno... so with your 400+ whp, you should easily be in the 11's for shore
https://www.evolutionm.net/forums/sh...=227902&page=2
Old Feb 5, 2008 | 06:12 PM
boostGotMeLaid's Avatar
i have the same setup but i went with a wisco pistons an eagle rods to see what i can max this turbo out to bc 280s 1000cc AEM and suporting mods cant wait to see what she does..
BTW are u using aem or no im acually looking for a map to break in the motor n clutch
Old Feb 5, 2008 | 07:28 PM
my 60ft time was in the sh!tter that day and that was the second run with the new setup. Had a new clutch put in during that build and still was learning how to drive it on the track. I think 11.9 with a almost 2.0 reaction time the quarter mile time was not bad.....if i was to go back today and race it...easy 11.6-11.7 on pump at 4000ft elevation track. Keep in mind the tuning was very conservative. Lucas does not like to tune to the point where the car in unsafe.
Too bad i wont be able to go to the track with this set up...but new set is gonna kick a$$.
Old Feb 6, 2008 | 08:43 PM
AZ-IX's Avatar
Mynes tuned my 57 trim kit also and i made 406 hp @24psi.....a little laggy and turbo falls off a little at high rpm...I went with their 3076 kit and much better performance
Old Feb 7, 2008 | 11:19 AM
the 57 trim shines with higher octane gas....someone need to throw some meth and see what that turbo can do.
V8HAHA
For Sale - Cars For Sale
19
Dec 24, 2015 08:12 AM
V8HAHA
Oct 7, 2015 09:31 AM
V8HAHA
Oct 4, 2015 07:23 PM
IHEARTevoIX
Aug 14, 2008 09:56 PM
ccbremech
23
Jun 13, 2008 06:27 PM
