stock turbo 26PSI
Old Feb 5, 2008 | 09:11 AM
tmaxxman21's Avatar
stock turbo 26PSI
im thinking i wanna retune to 25-26 psi on the stock turbo.. what other mods do you gusy think i should get to help this out
2005 evo 8 ssl, obviously has the 10.5 hotside
3" catless tbe
k&n intake
boost controller
fuel pump
tial bov
do you think i just need 770cc injectors?
if anyone else has these mods at this psi.. what kinda power you guys seeing?
Old Feb 5, 2008 | 09:14 AM
Mulholland0132's Avatar
3" catless tbe
k&n intake
boost controller
fuel pump
tial bov
You can run stock injectors if your willing to run meth. 27lbs of boost tapering easy with meth or alky. Without this not sure how safe that is?
Old Feb 5, 2008 | 09:16 AM
20Grockit's Avatar
if you have the k&n typhoon intake ditch that and that will help you out some. get a buschur or injen intake. get atleast a lower ic pipe, cams, meth inj. and you should put down some pretty consecutive numbers.
Old Feb 5, 2008 | 09:21 AM
spooch's Avatar
dont forget some head studs while your at it unless youdont mind replacing head gaskets
Old Feb 5, 2008 | 09:24 AM
20Grockit's Avatar
haha yea i shouldve mentioned that. might as well replace the head gasket while your at it too. i did my head studs and put in the greddy 1.2mm hg while i had the head off.
Old Feb 5, 2008 | 09:26 AM
th3_rEv8lution's Avatar
I've got a buschur intake, test pipe, and cat back with the stock downpipe. Kyle at DeiPro Tuning reflashed my ECU and I'm running 26psi with no other mods. I've been running this setup for 3-4 months now and I haven't had any problems. In fact the car drives and runs fantastic.
Old Feb 5, 2008 | 09:28 AM
Oh and by the way, I'm hitting 26psi at about 4500rpm and holding all the way to redline with no taper.
Old Feb 5, 2008 | 09:31 AM
RevMoto's Avatar
You need to stop helping people out. I have seen you say this so many times. Head studs are not needed and they are not insurance. Waste your own money and not other people's. You only hear things said by other members who are also wrong. Unless you have lifted a head then share. You cant so keep it to yourself. Not trying to sound like a dick but too many newbs repeating the same **** day in and day out. 10+ Evo's here running 32psi daily over years and have never lifted a head. You dont even have that.
Also when putting in the head studs, if you dont take the head off theres a very good chance that you will start leaking fluid or have a higher chance of lifting the head. When u do it with the head on you have to retorque then 2 or 3 times to garentee a good seal.
I looked at some of your other posts and was wondering if you work for ARP since you see to love to recommend headstuds to everyone.
Old Feb 5, 2008 | 09:33 AM
RevMoto's Avatar
For the OP yes you can run that much but I would definitely run meth. Running that high of boost all you are doing is taking away timing to allow you to run that number. You wont gain much hp but you will a little more torque. It is not worth it on pump but if you are adding meth then definitely go the high boost route.
Old Feb 5, 2008 | 10:18 AM
LV///R's Avatar
26psi to redline on the stock turbo? Interesting.
Old Feb 5, 2008 | 10:21 AM
Yup, I was just as surprised as you are, but just installed a boost gauge and thats whats it telling me. I'll try and take a video later today and post it up here.
mplspilot's Avatar
On what? 35r? Thread's about a stock turbo.
And if you're talking about a stocker you're full of BS. All 26 pounds of it.
No studs needed for stock turbo power levels.
To the OP:
You probably won't need bigger injectors with stock turbo, because it will taper to 19-20 psi by redline anyway. You do need to look at fuel though - better gas, E85 or alky is needed for higher boost.
Old Feb 5, 2008 | 10:24 AM
To the OP:
nope, i've got the stock 16g with 10.5 hotside. i'll get a video later. unless my boost gauge isnt reading right, i'm definately hitting and holding 26psi.
Old Feb 5, 2008 | 10:26 AM
lemmonhead's Avatar
he is right about the headstuds for insurance, without doing that your cutting really close to the factory safety margin, infact your out of the saftey margin. if he knocks at high load running 26psi that headgasket will give away pretty quick. mitsu alreaady had 5psi safetly margin boost (to 25psi) so 26 is already over that.
Old Feb 5, 2008 | 10:30 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Well I know it's not the case with everyone but some guys I know have had their head lift off the block. but running 26psi wow gas must be cheap in NH I'm only running 1 bar I only turn the boost controller on track days or when a 335i thinks they have a chance.
