FP HTA35r Dyno #’s w/ Meth
Old Feb 10, 2008 | 12:49 PM
JuniorAWD's Avatar
Originally Posted by 9sec9
Really nice job Freddy302. Were the tires slipping on spool up? Looks like around 4900 the torque/whp did something funky a couple of times. You're using the HTA35R exactly how it should be used on the street. Very nice! Congratulations.
It had a slight misfire coming up on boost due to the plugs...
Old Feb 10, 2008 | 12:59 PM
Duby's Avatar
I'm glad to see the torque is still high with that 35r on low boost.
Nice numbers
Old Feb 10, 2008 | 01:14 PM
6-speed's Avatar
+1 on the torque.
I'm amazed you made so much on the stock 2.0.
The HTA35 is looking like the ideal turbo for many Evo owners.
Now port the head, port the intake manifold, and get a larger throttle body to max that setup up .
Old Feb 10, 2008 | 01:49 PM
JuniorAWD's Avatar
The turbo is sick... Spools right on the money and holds a nice TQ curve.. I was very happy with it.. Freddy did an awesome job with the car... If you saw this car you would never expect the beat down you were about to recieve!
Kick *** Freddy! Had fun tuning her last night and I am glad I was able to help!
Old Feb 10, 2008 | 02:18 PM
ray3328's Avatar
Great numbers! I think I might send my turbo to FP.
Old Feb 10, 2008 | 02:41 PM
Wiznaz's Avatar
Great job guys.. those numbers are sick! I think I was leaving their facility right when you were pulling up on the dyno.. I had no idea!
Freddy
TheShop
Old Feb 10, 2008 | 02:45 PM
crcain's Avatar
At what RPM are you making 28 psi in 4th gear on the road?
Old Feb 10, 2008 | 02:48 PM
midwestmonster's Avatar
Does anyone know if this turbo would bolt up to the AMS manifold? Just wondering if the HTA35r would be an option down the road.
Old Feb 10, 2008 | 02:57 PM
JuniorAWD's Avatar
Yes it will bolt up.. Call up FP for specifics
Junior
Old Feb 10, 2008 | 03:10 PM
Freddy302's Avatar
Thanks Guys!
The bottom end is actually built. Jimmy from the shop ordered all the parts from Buschur and did all the work putting it together. The motor is quiet as could be, no crazy false knock cause of a "sloppy" or "loose" bottom end. Thanks JIMMY!
Yea Junior you did a hell of job on the keyboard getting this animal dialed in. Nice!
I have to go back to the shop and see exactly when it hits full boost.. But My guess is about 500-600 RPM behind my green, But that is just a guess.. I would guess full boost in fourth would be 4300-4400 rpm.
All I know is if you floor it at lower RPM, get ready for a fun ride and hold on then it really starts hitting hard WELL before 5000 rpm.
This turbo does everthing they say it does... Great Street\Strip turbo FP!
Old Feb 10, 2008 | 03:55 PM
TopLevelPerformance's Avatar
Great numbers Freddy, the HTA 35r is proving to be a very sick turbo. Jimmy, Junior and the rest of the guys at The Shop are great guys.
Old Feb 10, 2008 | 04:52 PM
SickSilverNLow's Avatar
is it a built 2.0?
Old Feb 10, 2008 | 04:55 PM
turboDan's Avatar
Originally Posted by SickSilverNLow
is it a built 2.0?
Originally Posted by Freddy302
Thanks Guys!
As seen a few post up,see in BOLD
Old Feb 10, 2008 | 04:57 PM
^opps....sorry just missed the little detail there.... WHat pistons and rods?
Old Feb 10, 2008 | 05:40 PM
U2SLO's Avatar
Nice numbers the HTA is a kick *** turbo.I was at No Limit Motorsports last night and put down 580hp on 27 psi pump gas only.It was cold out so I turned the boost down a little. They have the same dyno you tested on.
Seems like the .63 hotside made some good numbers.I'm running the .82
