ARP head stud failure.
We have a car here we are putting back together. It has been through a few too many shops and was a complete mess.
The new engine is going back together and we were torqueing the head studs, the same one the car came in here with. Luckily after doing a few thousand of these builds you get a feel for things. When something didn't feel right the stud was pulled out.
Below is a picture of the stud. We aren't sure why this happened (other than it was obviously tightened to tight past it's tensil strength). It is odd as we've re-used hundreds of ARP fasteners without a problem. My guess is someone in the past over torqued them and this was the result.
Be careful.
Be careful.
good info dave.. for the price of what standard ARP studs cost we require they buy new always and they can have back the old.. That is if we didnt do the original install and know how many times they have been on and off.. Just our policy..
The 75 ft lb ARP spec is not tight enough. The stud is not that strong and the diameter is "small". They can be torqued to about 90 ft lbs with no problem. Anymore and they stretch. In this case I am guessing someone attempted 100+ on them and that is not possible.
I suppose it could be a counterfit stud but it was probably just installed wrong before we got the car.
Cosworth has had a couple different part numbers for their head studs
The first ones were like the std ARP you see in the picture.
The new ones are L19(have not confirmed if ARP is the manufacturer or not)
The new part number MSRP out at $299 Where the old one was 187 or something like that.
Ben
Ben
