compression test. need help/info please
Old Feb 11, 2008 | 05:28 PM
EvoDan2004's Avatar
here is the HOW TOO
https://www.evolutionm.net/forums/sh...d.php?t=154364
I followed the how too to the tee
ok i did the how to which worked great but here are my results.
1. 170 at 7 cranks 180 at 10 cranks
2. 175 at 7 cranks 180 at 10 cranks
3. 175 at 7 cranks 180 at 10 cranks
4. 180 at 7 cranks 185 at 10 cranks
i did not know how many cranks to allow so i did a reading a 5 7 and 10. 5 was the same at 7 basically..
so to the pro's how is my compression looking???
to do a wet test how much oil do we add?? do we do it when the motor is hot as well??
03 evo8
stock block
60k miles
my reason for doing this is because
1 i just felt i should do it
2. i have a catch can off my pcv valve and when i cleaned it out it smelt like fuel real bad. the oil/liquid inside was very black and did not have the texture of oil at all. i guess the fuel broke the oil down.
3. to learn more and get hands on.
Old Feb 11, 2008 | 05:35 PM
lemmonhead's Avatar
sounds great to me, that oil crap out of the PCV is normal. mine is black and hard as a rock when its cold out, and when warm looks watered down oil or something.
all normal dude.
Old Feb 11, 2008 | 05:38 PM
EvoDan2004's Avatar
all normal dude.
i know oil coming out of the pvc is normal. but mine stinks like gas/fuel. looks black like oil not thick at all. very very thin.
Old Feb 11, 2008 | 07:11 PM
Zeus's Avatar
Think which is more likely to be "vapor"... then think which could you possibly "separate" more of with your catch can design.
Compression looks ok in my book, but then again, I'm not one of the "known" Evo engine builders here.
Old Feb 11, 2008 | 07:12 PM
E VOL IX's Avatar
uir good...mine is only around 150 on every cylinder... if u are seeing 175 and such you are golden
Old Feb 11, 2008 | 07:40 PM
EvoDan2004's Avatar
zeus
hey bro. hope all is well. thanks for your input.
E VOL IX
thanks a lot. should i still do a wet compression test? or do you think its not needed.
do i do them while the motor is hot? and how much oil in enough. i dont want to put to much or to little.
Old Feb 11, 2008 | 07:43 PM
E VOL IX's Avatar
no not needed...
wet test is only when you see very low numbers like 100 or less... trust me you have nothing to worry about at the moment... im building one now that read 0-100-100-100... that my friend is when u are fuqqd
Sean@Iveytune's Avatar
Do a leakdown test.
Sean
Old Feb 11, 2008 | 07:46 PM
EvoDan2004's Avatar
Originally Posted by E VOL IX
no not needed...
awesome. thanks a lot. im going to slap in some new plugs. give her fresh blood ''oil change'' and call it a night.
EvoDan2004's Avatar
Originally Posted by Sean@Iveytune
Do a leakdown test.
Sean
sean
leak down test? fill me in here. like a boost leak test?
Old Feb 11, 2008 | 07:50 PM
E VOL IX's Avatar
no.... I will let sean handle this one.. im going to bed
Old Feb 11, 2008 | 08:00 PM
EvoDan2004's Avatar
cool man. have a good night. thanks for you info.
Old Feb 11, 2008 | 10:04 PM
RazorLab's Avatar
That's because you have a 9 and he has a 8.
Originally Posted by evodan2004
sean
Leak down test is when you put the cyl to TDC, fill it with air via a leak-down tester and measure it for any leak past the valves or rings.
Your Comp test looks pretty good and not much variance between cylinders, imho a leak down test isn't really needed but if you are being **** then go for it.
Old Feb 12, 2008 | 04:04 AM
EvoDan2004's Avatar
Thanks. Yea I don't have what I need to do a leak down test so I'm not going to worry about it. The main purpose I figured I would check all this stuff is because the car is starting to make some good power and I just wanted to make sure all was well befor I start to push it a little harder. I'm doing a build soon but would still like to know what I have is doing well. Thanks everyone for there input and help.
Old Feb 12, 2008 | 07:50 AM
HaVoC RR's Avatar
Im sure u feel better now
