compression test. need help/info please
Old Feb 12, 2008 | 10:02 AM
ONRAILS's Avatar
You cant really compare compression numbers to others.
different Cams will cause changes in compression numbers
Old Feb 12, 2008 | 01:17 PM
EvoDan2004's Avatar
ok then how do i know if my numbers are ok??
holy crap.
Old Feb 12, 2008 | 01:25 PM
Zeus's Avatar
There is a "range"... most important is difference from cylinder to cylinder... YOU ARE FINE!
Old Feb 12, 2008 | 01:26 PM
EvoDan2004's Avatar
hehehehe. u know me to well. ok ill stop being paranoid now. haha. thanks
Old Feb 12, 2008 | 01:30 PM
RazorLab's Avatar
Yes you are fine, as long as you are within factory spec and not a huge variation between cylinders you are good to go.
if you want more assurance, my personal Evo 8 that has seen a billion dyno hours, over 18 open track events, 30+ psi at times, etc etc also has 180 compression across.
Old Feb 12, 2008 | 01:33 PM
EvoDan2004's Avatar
im going to sleep good tonight.
thanks
drb's Avatar
drb
Wow, a billion dyno hours, I'm guessing this is just a rough estimate!
Old Feb 12, 2008 | 01:35 PM
EvoDan2004's Avatar
some kind of new record im sure. heeheh
Old Feb 12, 2008 | 04:46 PM
Zeus's Avatar
xRoguex
Dec 6, 2021 07:58 AM
khoyer
Dec 6, 2016 10:00 AM
marinejensen
16
Jul 7, 2015 07:18 AM
ozmitsu03
Aug 1, 2011 03:56 AM
the_cosworth
Lancer Engine Tech
56
Aug 9, 2007 09:16 PM
