Help with slave cylinder install
Old Feb 14, 2008 | 05:25 PM
xLaNcErEvOx's Avatar
I just bought a new slave cylinder for my clutch because the pedal recently lost pressure. Well other than just replacing it, do i have to bleed anything or do any precautions?
Old Feb 14, 2008 | 06:38 PM
Evil_1's Avatar
So what made you think it's the slave cylinder? You could just have air bubbles in your clutch lines, possibly a leak somewhere, low on clutch fluid. Why don't you try bleeding the system first and see if that helps before installing the new slave cylinder. Yes you do have to bleed the system after installing new slave cylinder.
Old Feb 15, 2008 | 02:58 PM
thats the thing, i dont know how to bleed the clutch system and i need help with that.
Old Feb 15, 2008 | 04:31 PM
Max Power's Avatar
Searching is your friend...
http://evomoto.com/tech_info.php?tPa...dacb2e91385ab2
URNVS
May 30, 2013 02:59 PM
Jokiesmurf
17
Jul 23, 2012 07:37 AM
mitsuevodriver
38
Nov 22, 2010 08:54 AM
milruner
Lancer Tranny/Drivetrain Tech
Dec 6, 2009 04:33 PM
