04-06 Ralliart Engine/Drivetrain (no forced induction)
Is there a way to adjust the clutch engagement point?
Old May 30, 2013 | 11:10 AM
URNVS's Avatar
I just picked up an 04 Ralliart and Im not loving how close to the floor the clutch engages. Is there a manual adjustment for this or do I have to fabricate something like a custom length slave cylinder pin?
Old May 30, 2013 | 12:06 PM
2006_RA's Avatar
Yes, there is an adjustment by the pedal.
Old May 30, 2013 | 12:57 PM
URNVS's Avatar
I saw those instructions earlier, but if I read it right that adjustment is for the pedal height not for the engagement point...? I dont want the pedal itself sitting higher off the ground but rather I want the clutch to engage about 2" higher than it does now.
Old May 30, 2013 | 01:09 PM
CrAnSwIcK's Avatar
you have to shim or remove shims from the clutch fork fulcrum...
Old May 30, 2013 | 01:11 PM
URNVS's Avatar
Thanks...any links to DIY instructions or pics of the location in question?
Old May 30, 2013 | 02:25 PM
lanzerralliart's Avatar
EvoM Super Moderator
It's in the owners manual, I'm sure if you do you do a quick search it's been covered.
Old May 30, 2013 | 02:59 PM
2006_RA's Avatar
Look on the car and you will see.
kanovic
Dec 13, 2015 01:19 PM
JEP
May 13, 2011 05:55 PM
wicked white14
May 6, 2009 03:51 AM
madmax4499
19
Nov 11, 2007 08:51 AM
smokedmustang
51
Sep 20, 2006 05:30 PM
