Evo 9 MR oil drain plug crush washer question
Old Feb 20, 2008 | 07:12 AM
sblvro's Avatar
get a new filter. is it oem mitsubishi or aftermarket that you have now. stick with oem.
Old Feb 20, 2008 | 07:32 AM
ajstefanacci's Avatar
sometimes you can mistake the retainer for the crush washer, after it has been bent, as the crush washer
Old Feb 20, 2008 | 09:22 AM
DubloEvo's Avatar
It is OEM. I checked part numbers on the one that came off the car and the new one and they are the same. It still has a slight leak.. I wonder if the one I have is defective or warped or something.. I didnt see any drips on the driveway this AM but after I wiped it off yesterday and checked it this AM it had some oil on it.
Old Feb 20, 2008 | 10:40 AM
Rod Munch's Avatar
I have seen the crush washer issue on this forum before. Without doing a search, I recall that some people's Evos did not come with a crush washer from the factory, as they learned on their first oil changes. That's how mine was. Five oil changes later, I still don't use any washer, and it does not leak.
Old Feb 20, 2008 | 03:23 PM
edmundo's Avatar
Old Feb 20, 2008 | 09:37 PM
waynea's Avatar
I have a thought and it may be too basic, but the community will correct me if it is wrong. I typically dub a small amount of oil on the seal of the oil filter before installing. I remember being told that if you don't it may leak or stick.
Originally Posted by DubloEvo
Anyone else experienced a really slow oil filter leak? I tightend it to spec and I wiped the filter off and still see where the filter is still leaking just a hair. Any suggestions? Get a new filter?
Old Feb 21, 2008 | 09:02 AM
DubloEvo's Avatar
Yep I did that too.. the filter actually had some sort of prelube on it.. but I put some oil on it anyways. It looks to have stopped leaking after I took it off, checked it out then re-tightened it.
Old Feb 22, 2008 | 05:12 PM
joec's Avatar
If the oil filter is leaking, make sure that the old rubber gasket from the previous filter didn't stay stuck to the filter housing. If so, when you put on the new filter (with its own rubber gasket) it doesn't have enough thread engagement and can leak or pop off.
Old Mar 9, 2008 | 01:42 AM
dyablo's Avatar
Anyone have the part number from mitsu for those silver looking crush washers? I use oem filters and need some of those washers. Thanks.
Old Mar 9, 2008 | 06:12 AM
michaels_evo8's Avatar
The first time i changed the oil in my Evo 8 the oil pan with the bolt and crush washer was all painted at the same time.. when i removed the drain bolt you couldnt even hardly tell that the crush washer was since the paint was holding it in place. I knew there had to be one there and after a gentle pry with a small flate blade it popped right off.
Old Mar 9, 2008 | 01:46 PM
kainam00's Avatar
Make sure you don't over tighten the filter when putting it on, that can make it leak as well.
Old Mar 9, 2008 | 02:21 PM
Burklow's Avatar
If it still leaks or you're worried about it, just re-do the oil change. It isn't terribly expensive, and you could still use your filter on there now since it is brand new.
Old Mar 12, 2008 | 09:12 AM
dyablo's Avatar
anyone?
Old Mar 13, 2008 | 10:32 AM
dyablo's Avatar
Originally Posted by saiyanzzrage
go to the service window at the dealership and ask for one
people are truly useless..
yeah if it wasnt three hours away maybe . Perhaps I should try calling .
Thanks tho.
Old Mar 13, 2008 | 06:12 PM
rcheung's Avatar
Part number is MD050317
