hmm, weird oil leak.. help!!
Old Feb 24, 2008 | 02:12 PM
psphinx81's Avatar
took the car for a ride around the block today since it was pretty decent out, then while pulling back into the garage i notice a pretty steady trail coming from the car when i got out.
any suggestions where this is coming from? what should i check into first.. does it look like an oil pan gasket leak? it kind of seems its coming from behind the black plastic piece right there, not sure though!
^^ drips directly down onto the line
Old Feb 24, 2008 | 02:37 PM
psphinx81's Avatar
ok, just took off the cam gear cover. there is oil on part of the cam gear cover and all over the belt.. nothing seems to be coming out of the cam seals
Old Feb 24, 2008 | 03:36 PM
psphinx81's Avatar
another update
checked out the dipstick to see if any coolant is getting in my oil, looked perfect.. so i dont think its a head gasket at this point
Old Feb 24, 2008 | 03:44 PM
MR Turco's Avatar
Looks like the cam seals.
Old Feb 24, 2008 | 03:46 PM
bluebyu36's Avatar
bump for good luck....
Old Feb 24, 2008 | 03:53 PM
DocMortal's Avatar
cam seal.. When I did my cam install I put a good amount of rtv.
YellowEvilEvo's Avatar
either cam seal or head gasket....
Old Feb 24, 2008 | 05:20 PM
evoboi005's Avatar
looks like cam seal and shouldn't you change the timing belt and clean all the oil off everything now that every pulley and tensioner is covered in oil
Old Feb 24, 2008 | 05:27 PM
Curt@MrLed's Avatar
Former Vendor
Do not drive your car anymore. Fix the leak. If you dont the belt will snap very soon and you will be rebuilding your engine.
Old Feb 24, 2008 | 05:37 PM
psphinx81's Avatar
the car isnt moving untill i find what's leaking, i will top off my oil and start it tomorrow to see where its coming from.
the engine bay will be degreased and cleaned before it comes out again.
dont think its a headgasket, nothing in the oil and coolant levels are good
Old Feb 24, 2008 | 06:35 PM
vwjeff's Avatar
Crank seal or Cam seal, front cover... I dunno. I never had a 4g63 apart
Tow it to Buschurs
Old Feb 24, 2008 | 06:38 PM
evo_08's Avatar
oil pump shaft seal.
Old Feb 24, 2008 | 07:23 PM
EmeryatSTM's Avatar
seeing as how the back side of the exhaust cam gear is wet I would start there (cam seal).
-Em
Old Feb 25, 2008 | 03:45 PM
psphinx81's Avatar
got it, it was my valve cover gasket lol.. took it off and the gasket was in 5 pieces where it was leaking
atleast it wasnt anything serious
Old Feb 25, 2008 | 04:28 PM
barneyb's Avatar
I'm happy to hear you found the source of the leak. However, if there is oil on the timing belt it is still serious.
