Evo 8 Vs Evo 9 Block Differences?
Old Feb 27, 2008 | 08:26 PM
Tim@AMSperformance's Avatar
The differences are that on an evo 8 the oil pressure sending unit screws into a small tapered thread hole in the back of the block, and an evo 9 has that same hole tapped to i believe 12mm. This is then used with a banjo bolt to feed oil through a pipe to the cylinder head. An evo 9 has the oil press, unit down on the oil filter bracket. You can drill the evo 8 block to accept the evo 9 banjo bolt but you cant go from an evo 9 to an 8
Old Feb 27, 2008 | 08:45 PM
RIP SVT's Avatar
Thats sounds like a good answer thanks for all the help
Old Feb 29, 2008 | 05:05 PM
RIP SVT's Avatar
bump
Old Jan 18, 2009 | 01:29 PM
allday10sec's Avatar
so theres no way of going evo 9 block on a evo 8 head????
can anyone verify that
Old Feb 5, 2009 | 10:11 AM
josh prochaska's Avatar
yes u can use a 8 head with a 9 block but u need to put an adapter in place of the banjo bolt to put your oil presser sending unit to the block.
Old Feb 5, 2009 | 10:14 AM
they are the same block. Just one hole on the block is taped to a different size.
Old Jul 5, 2010 | 05:05 PM
chrisw's Avatar
sweet.... mivec here I come.
Old Jul 6, 2010 | 10:30 AM
20gmr's Avatar
Its thread differences, are you serious? why don't you guys develop an adapter kit. one from 8-9 and on from 9-8. i have been thinking about it and the easiest way would be to make a braided steel oil line to come from the mivec solenoid to the tapered thread in the block.
the other way around would be even easier. Buy yourself a ix filter housing and plug the whole in the block...done
Old Jul 8, 2010 | 12:51 PM
we do offer a kit to go from 9-8. It should be in our cart
Old Jul 8, 2010 | 02:51 PM
nyquil2's Avatar
why dont ppl just buy a Evo 8 block if they have a 8 head n 9 block if they have a nine head... would make life much easier
Old Jul 9, 2010 | 01:43 AM
meld's Avatar
I have buschur built block in my IX. I use a Buschur oil line kit they offer to go to my MIVEC head.
Old Aug 27, 2016 | 05:02 PM
Biyikevoviii's Avatar
Anyone have an Evo 8 block for sale. Need one asap 😭
Old Aug 27, 2016 | 05:25 PM
Biggiesacks's Avatar
probably better to post this in the classifieds section instead of bumping an 8 year old thread.
Old Aug 27, 2016 | 05:41 PM
i would but it for some reason does not let me. 😔
n2oiroc
May 27, 2017 01:39 PM
Howulikemyevo
11
Apr 17, 2017 09:55 AM
yellowevo82
16
Sep 30, 2016 03:35 PM
maperformance
Feb 29, 2016 07:56 AM
maperformance
EvoX 'For Sale' External Engine / Power
Feb 9, 2016 09:02 AM
