Borg Warner s256 NO COOLENT THROUGH TURBO????
Old Feb 25, 2008 | 02:49 PM
mitsuboost30's Avatar
Exclamation Borg Warner s256 NO COOLENT THROUGH TURBO????
Is this safe that the borg warner does not have coolant running through the turbo... i mean every turbo ive ever seen has this?? OPINIONS PLEASE!!
Old Feb 25, 2008 | 02:58 PM
justboosted02's Avatar
yeah its fine, just buy a turbo timer
Old Feb 25, 2008 | 03:01 PM
Exciting News's Avatar
Ummm.... It's an oil cooled turbo.
It's, like, designed that way...
Old Feb 25, 2008 | 03:05 PM
UMM ok like i knew that........ POINT OF THE THREAD.. DUUUUHHHHH
Old Feb 25, 2008 | 03:23 PM
Spoolin18's Avatar
Well now you do .
Old Feb 25, 2008 | 03:28 PM
Originally Posted by Spoolin18
Well now you do .
THANKS FOR THE RECAP!!!
Old Feb 25, 2008 | 03:32 PM
Nez136's Avatar
thanks for the caps
Old Feb 26, 2008 | 06:17 AM
joeracer321's Avatar
I would say that if you have never seen an oil cooled turbo before you don't get out very much.
Old Feb 26, 2008 | 03:57 PM
VRSF Tiago's Avatar
A lot of aftermarket turbos aren't watercooled. They won't last as long as a factory turbo will but it shouldn't make much of a difference anyway.
Old Feb 26, 2008 | 04:11 PM
CBRD's Avatar
or just have us use a garrett center section with BW wheels
cb
Old Feb 26, 2008 | 04:40 PM
cb
Would that be a Ball bearing with Extended Tip technology turbo?
Hmmmm.....
Old Feb 26, 2008 | 11:58 PM
chuntington101's Avatar
cb
hmmmm, as /\/\/\/\ said above, could this be the ultimate turbo?!?!?
Chris.
Old Mar 26, 2008 | 07:29 AM
Keith-PURE Tuning's Avatar
Former Vendor
We have people ask that question all the time. I find it rather funny because most turbos use to come oil cooled only and then coolant ports were added because turbo manufactures found people weren't changing there oil at the scheduled intervals. This was like 20+years ago. Now people have become so use to water cooled turbos the standard has become reversed.
Oil quality and durability is considerably better than even ten years ago making coolant ports a design the turbo manufacturer determines necessary. If the turbo is only oil cooled like the BorgWarner"'s then it is strongly suggested to have a air-to-oil cooler. This would be no different when upgrading to a larger turbo with coolant ports and making sure your cars coolant system is capable of handling higher temps from the new turbo. If not then a larger capacity radiator would be the proper supporting upgrade needed. The Honda guys know all about this.
Most street cars don't have issues with either as long as synthetic oil is used and changed when needed, car is at full operating temp before getting its *** kicked, and given at least 30sec of cool down when done.
03nevaevolution
Oct 14, 2010 06:13 PM
quicky4JR.
12
Feb 15, 2008 07:47 PM
thatsMR2u
37
Jul 29, 2007 10:16 PM
