Intake hard pipe question
Old Mar 19, 2008 | 07:18 PM
BluEVOIX's Avatar
I thought people where having issues with intake pipes because of the unmetered air entering?
Example:
With the stock setup, fresh air is pulled into the valve cover from the intake pipe after it flows passed the maf (metered). But many intake pipes are capped and you cant run the stock like routes. There for you have no choice but to put a breather filter on the valve cover. With a breather, unmetered air from the atmospher is drawn in and into the intake manifld after the valve cover, and causing idle problems etc...
Stock
After market intake
EvilTechnology's Avatar
What don't you like about the AEM one? Lucas seems to prefer the AEM.
Old Mar 19, 2008 | 07:53 PM
ChuckP's Avatar
Example:
Stock
After market intake
Huh? Hard intake pipes are fine. BOVs cause issues.
Old Mar 19, 2008 | 08:06 PM
Billy@EnglishRacing's Avatar
It does work well, i just don't like where the maft sits, in the end it is just a personal preference
Old Mar 19, 2008 | 08:14 PM
Gotcha. Where does it actually end up?
Old Mar 19, 2008 | 08:19 PM
right next to the upper pipe
Old Mar 19, 2008 | 08:27 PM
I see. Pretty much where mine is now with the Samco
Old Mar 19, 2008 | 09:28 PM
BluEVOIX's Avatar
I'm not saying hard intake pipes are bad or will cause problems. What I'm trying to say is any after market intake pipe that forces you to use a breather on the crank case, then it might cause some small problems such as rough idling etc.. due to the unmetered air theory. Unless tuned for it...
I personally think that hard intakes flow better than the stocker because they dont have the ridges inside. And the less bends and angles it has, the better. Similar to exhaust setups with less bends being better.
Old Mar 19, 2008 | 09:36 PM
The rough idle can be tuned out for the most part
Old Mar 19, 2008 | 09:46 PM
EVOlutionary's Avatar
Get the PPI intake pipe. Works and fits perfectly.
http://www.paradigmperformance.net/p...vo/intake.html
Has the nipples to connect all the stock hoses, and allows you to use the stock airbox if you still have that, or an open cone filter on the MAF sensor.
Old Mar 20, 2008 | 07:44 AM
That's not a bad looking pipe. Anyone have any upclose pics of where it actually connects to the turbo?
Old Mar 20, 2008 | 08:00 AM
mdsevo06's Avatar
I have the ETS Intake pipe, and my MAF sits right over the Short Route UICP. I used a rubber foam to seperate the two, so there's no vibration or rattling. If I had to do it again, I would get the AEM that comes with a shroud.
Old Mar 20, 2008 | 08:25 AM
PPI's Avatar
PPI
Is there something you want to see in particular? I think I have one I can dig up. Its a full 3" pipe that uses a 3" to 2.5".
Thanks for posting the link Evolutionary
Old Mar 20, 2008 | 06:07 PM
dbsears's Avatar
The AEM is probably the most hated intake of all. They have a rubber flapper inside that messes with the idle. You can remove it but you are better off with ETS or PPI. Also if you want less drivability issues look for one of the airfilters that bolt directly to the MAF and dont use a maf adapter (ie: buschurs older styled one). One other thing is the HKS air filter filtration isn't the greatest so I would keep them clean. The big thing is the MAF wants to read laminar airflow. Pipes with different bends and airfilters that connect with maf adapters usually affect the maf some. You want the air to come in at the straitest possible angle and not create turbulence.
Old Mar 20, 2008 | 07:29 PM
I ran the PPI style pipe for probably 30K miles with no problems. It is the same size and shape as the stock rubber pipe, just smooth on the inside. If anything I would think it would smooth out flow?? IDK, must my 2 cents. . .
