BR Cams-Need Info on these please?
Old Mar 1, 2008 | 06:35 PM
Billy@EnglishRacing's Avatar
+1 on the jun 272's
Old Mar 1, 2008 | 06:41 PM
1slowevo's Avatar
Originally Posted by turboDan
See 1slowevo and see if he can make a video or at least sound from them as he just installed a set on the stock ecu and he says they idle alright,with some tweeking to his ecu.
you let the cat out of the bag Dan.
now I have no tricks against Mike1023
Old Mar 1, 2008 | 07:48 PM
David Buschur's Avatar
I am not giving out the specs on the cams. There are some good cams out on the market. I have said that in the past. The JUN 272's work well, the Tomei 280's work well. We did a bunch of cam testing and then sent in multiple sets of cams to the company that made them for us, we had them look at the cams that worked well and told them to make us a cam based on the information they found from the cam sets we sent them for the best overall cam.
Judging from the power my RS is making and the power we are making consistently on pump gas on many other builds, I'd say the cam was ground correctly to give us what we wanted.
I do not suggest the cams for use with the stock ECU, I do not feel the idle is going to be good at all. You will also need a set of very high quality valve springs.
Old Mar 1, 2008 | 07:51 PM
EvoDan2004's Avatar
so will the dual valve springs and such you sold me about 1 year ago when i got my revolver cams work perfectly or do i need a better set?
Old Mar 1, 2008 | 08:06 PM
1slowevo's Avatar
I agree your cams are the ****. I have them currently on the stock ecu with some tuning we got the car to idle pretty decent. I think it is much easier to get the tune right on the stand alone, but the stock ecu has come along
Yes, if you bought duals from us a year ago they should work fine.
Old Mar 1, 2008 | 08:07 PM
Boost3dxEvO's Avatar
Even though you say they aren't okay for the stock ecu.. I will still give them a shot (: I plan on AEM EMS if the stock ecu does not work out... Are supertech dual springs and ti retainers good for these??
Thanks (:
Old Mar 1, 2008 | 08:12 PM
EvoDan2004's Avatar
Thanks (:
he just said yes and we have the same valve train.
Old Mar 1, 2008 | 10:33 PM
vwjeff's Avatar
Originally Posted by evodan2004
+1 on the vid idles and such.
http://www.youtube.com/watch?v=AeFMoCbdVEo
Old Mar 1, 2008 | 10:45 PM
ApacheFixer's Avatar
whats the idle at? it sounded a little high
Old Mar 2, 2008 | 06:34 AM
EvoDan2004's Avatar
sounds good but it seems to be idling kinda high. no lop. or maybe thats just how they are
Old Mar 2, 2008 | 06:38 AM
EvoDan2004's Avatar
here are my revolvers on stock turbo stock ecu and alot of other stock parts.
i since upgraded tbe, turbo kit, and alot more. it sounds much much meaner now. this vid was also almost untuned. 1 or 2 tweeks.
http://youtube.com/watch?v=QWG2LrGEFhE
i might miss this idle.
Old Mar 2, 2008 | 06:39 AM
The idle may have been still on the cold start in the video, it does sound a little high. Even on the cars with stand alones I set the idle at 1100-1200 with the big cams.
Old Mar 2, 2008 | 06:46 AM
EvoDan2004's Avatar
i will agree with this. i have herd a set of br cams on a cold start. but damn it was to cold to here it all warmed up so we all just hit the road.
^pete's car.
Old Mar 2, 2008 | 07:01 AM
evoPirate's Avatar
You can't go wrong with BR parts! Now order them up so you can get your Cosi's out of the car lol
