Max safe power stock internals
Old Mar 8, 2008 | 03:11 PM
extremier's Avatar
Hi, I know it depends on the use and abuse, but please...
What is the max horse power that stock internals (pistons, rods, bolts) can safe handle?
My projet include FP green, and cosworth 272 cams + turbo xs FMIC + full blitz exhaust, bigger injectors, and BOOST !!!
Thanks a lot for all the imputs.
Old Mar 8, 2008 | 03:13 PM
bluebanana23's Avatar
I think you'll get a lot of different answers here ,but I read 500 whp is the most you want to push out of your stock block.
Old Mar 8, 2008 | 03:15 PM
freddiet's Avatar
Been on this site for a long time. And that is also what i have heard..
Old Mar 8, 2008 | 03:21 PM
Ambiguous's Avatar
I remember reading a thread somebody posted that HKS did some testing on the stock bottom end and found that around 400 HP is about the most you can make to be on the safe side. I believe after 400 HP they started seeing connecting rod failure...? There is quite a few ppl out there running around 500 HP on stock bottom end with no problems. With the mods you have in mind, you should be fine on stock internals.
Old Mar 8, 2008 | 03:22 PM
psphinx81's Avatar
you'll be fine with an FP green and the supporting mods, im pushing 550+ through the stock block/head without any issues
Old Mar 8, 2008 | 03:24 PM
Spoolin18's Avatar
Rod bolts are questionable on the stock block.
Old Mar 8, 2008 | 03:29 PM
Ambiguous's Avatar
Thanks for the clarification
Old Mar 8, 2008 | 03:44 PM
Boltz.'s Avatar
FCOTM Winner
The weakest point as I understand is the stock rods.
Other weak points are the ringlands and the rodbolts.
Old Mar 8, 2008 | 03:52 PM
EvoTech's Avatar
I think 500 is about the limit. Can you go higher? Sure but for how long. At the very least, I would do rod bolts over 450.
Old Mar 8, 2008 | 07:11 PM
extremier's Avatar
Thanks a lot ! So 400 HP stock internal is fine .
Thanks a lot for the the replies...
So I guess 400 hp would be fine with stock internal.
Shortly I will go for wiseco/eagle.
Once again thanks for all informations.
Old Mar 8, 2008 | 07:27 PM
jmartinez1170's Avatar
550whp there you go maybe if you did a SEARCH ( YOU WOULD KNOW THAT)
Old Mar 8, 2008 | 07:30 PM
Billy@EnglishRacing's Avatar
550 is about right, your green maxed out shouldn't be above what you motor can handle
Old Mar 8, 2008 | 07:37 PM
ImprezvSE's Avatar
The only thing in my motor is cams and a lot of pressure and I'm commin up on 4k mile with the set up and no problems.
Old Mar 8, 2008 | 07:49 PM
Boost3dxEvO's Avatar
500awhp is the max on the stock internals... You won't personally need to worry about that with the green and mods you plan on doing . Good luck.
Old Mar 8, 2008 | 10:56 PM
hokiruu's Avatar
keep in mind, making 500+whp on stock internals on a dyno and opening it up once in awhile like just weekend fun without blowing up, vs. 500 whp daily driven hard on the street, vs. 500whp raced hard regularly are not the same.
I know 550whp is doingable on ths stock bottom end, but 400whp seems much safer.
