what have I done
Old Mar 9, 2008 | 12:24 PM
nothere's Avatar
what have I done
guess I drove the evo with the turbo to manifold bolts loose. torqued to spec but should have checked them latter. pretty hard driving, maybe twenty laps on a road course and 180 miles home.
my question: since only part of the gasket was left when I pulled it out what have I done to the turbo?
it is making about 9 psi less than it did before and spool is slower. no smoke.
second question: did I ruin exhaust valves running with an exhaust leak at the manifold? Is that what is the problem with the turbo?
thanks, learning the dumb way.
Old Mar 9, 2008 | 12:33 PM
RevMoto's Avatar
Loose bolts will not ruin a turbo. If you have a large exhaust leak you are going to see a substantial loss in spool up. I have found even if not torqued to spec that it will be fine. Gasket missing is a huge issue a lot of drifters have when beating on the car for a long period of time. Haven't heard much of it on our cars. As far as the turbo goes then I would think it would be fine. Do a boost leak test to make sure you get all the small things out of the way before you blame the turbo.
Old Mar 9, 2008 | 12:40 PM
nothere's Avatar
I'm thinking part of the gasket burned up in the flow.
I first noticed something was wrong when the boost gauge only read about 14 lb.
After putting a new gasket on and checking clamps I'm getting 17 instead of 25.
So no issues with exhaust valves?
Old Mar 9, 2008 | 12:47 PM
RevMoto's Avatar
Valves have nothing to do with it. You probably have a boost leak due to inconsistent spikes.
Old Mar 9, 2008 | 02:47 PM
Brian's Avatar
what kind of gasket were you using? The stock one?
Old Mar 9, 2008 | 02:58 PM
meckert's Avatar
if the valves were burned you wouldnt have any compression or very little....and idle would be crap if it ran at all...so back to a leap some where
Old Mar 9, 2008 | 03:46 PM
nothere's Avatar
thanks for the help guys.
after checking the turbo for obstructions / tightening clamps, I thought I'd check the cat. That is where my problem was. It was dislodged inside the perrin hfc... too much back pressure.
replaced it with a test pipe (temporarily) and the world, no, I can breath easier.
Old Mar 10, 2008 | 12:00 AM
evospecialist's Avatar
use the test pipe on race day even high flow cats get stupid hot and the issue wil happen again eventualy. good luck
mspandl
Feb 18, 2018 07:04 AM
Thugline
Sep 12, 2016 05:31 AM
Zandalution IX
Nov 8, 2014 03:55 PM
abazaba410
Oct 28, 2013 03:39 PM
skochur
11
Jul 18, 2009 02:16 PM
