Exedy HD Twin Weight?
Old Mar 11, 2008 | 09:35 PM
rawkus's Avatar
I just got my Exedy HD twin and am installing it, and I noticed it is substantially heavier then the standard clutch/flywheel combo and I was wondering how this affects driveability. I do a lot of road racing and autox. I was pretty disappointed actually as I am really a fan of lightweight flywheels in my previous cars.
Dan
Old Mar 11, 2008 | 09:45 PM
rawkus's Avatar
Opinions on selling this and switching to Quartermaster? Is it lighter? Thanks.
Dan
Old Mar 11, 2008 | 11:40 PM
evospecialist's Avatar
stick with the exedy its a nice piece of equipment. It does not affect driveability. It is actually very nice to drive. The flywheel is not the heavy part on the exedy twins its the Intermediat plate it wont hurt your power. i have not had a qautermaster twin to drive yet. but i have my exedy its great and i have installed quiet a bit.
Old Mar 12, 2008 | 06:38 AM
KevinD's Avatar
the different clutch weights are pretty well documented. the exedy twin is about the same as the stock clutch/flywheel. if you want something light weight, try the ralliart twin, it is as light as a carbonetics twin carbon but its not carbon. for something that isn't astronomically expensive, you could always go to a single plate with an ultra light flywheel. the ACT prolite flywheel is about 10 pounds. the fidanza aluminum flywheel is sub 10 lbs
Old Mar 14, 2008 | 08:35 AM
rawkus's Avatar
I went ahead with the Exedy and I am pretty happy so far. The weight really hasn't affected driveability much. I take it a lighter clutch disc helps the synchros because shifting is improved, which is what I wanted to improve the most.
Dan
Old Mar 14, 2008 | 08:46 AM
Spaceball 1's Avatar
What its still rotating with the motor and rotating weight robs HP
Since you have already installed the Exedy or decided to keep it, the weight will actually makeing driveing the car easier/better. The light weight clutch disks in it will be much better on your trans and esier to shift faster.
Old Mar 14, 2008 | 08:48 AM
However i don't mine driveabilty and do alot of roll racing so i went with a ACT prolite flywheel and a 6 puck unsprung to have almost the lightess clutch disk and flywheel possible for the money.
Old Mar 14, 2008 | 06:12 PM
rawkus's Avatar
I imagine on a turbo car a heavier flywheel has its advantages. I am actually very satisfied, rev matching is still very easy and the shifting has improved greatly. I would love to have a twin disc with an aluminum flywheel to compare driveability with this current clutch.
Dan
Old Mar 14, 2008 | 06:14 PM
wizzo 8's Avatar
I weighed mine at 29lbs. How much does a stock clutch with flywheel weigh?
Old Mar 14, 2008 | 06:33 PM
TTP Engineering's Avatar
32lbs. They are near identical.
Old Mar 15, 2008 | 08:14 AM
wizzo 8's Avatar
So the twin is actually 3 lbs lighter? Sounds good to me
Old Mar 15, 2008 | 09:04 AM
rawkus's Avatar
I didn't weigh the two combinations, but the stock felt significantly lighter... I can weigh the stock one soon though.
Dan
Voltexed
Mar 1, 2017 11:40 AM
romogst
Aug 22, 2013 06:57 AM
Dragracer187
Apr 3, 2010 01:58 PM
Inprogress
20
Jan 31, 2009 01:36 PM
StevenStarke
Dec 10, 2007 11:46 AM
