New Launching Aide Innovation
Old Mar 18, 2008 | 05:05 PM
  #211
Indy Evo's Avatar
edited
Old Mar 18, 2008 | 05:16 PM
  #212
midwestmonster's Avatar
Thanks. I will.
Old Mar 18, 2008 | 05:36 PM
  #213
tabio42's Avatar
midwest monster - with the AEM you will have a lot of options. I see that you were tuned by AMS and I am positive they can set it up for you.
The EMS has a bunch of spare inputs (switches) that you need to ground to activate. Then you can configure your high side (switch to power) or low side (switch to ground) outputs to switch over a relay to activate the launch aide when your input switch has been activated. Then you set parameters for your output based on RPM, Load, TPS, Vehicle Speed.
I was thinking the easiest way to do it is just have it turn off at a specific speed before you shift into second. That way you just flip a switch at the beginning of your run to turn it on and just drive. The EMS will automatically turn it off.
Old Mar 18, 2008 | 05:43 PM
  #214
urslo4n8's Avatar
THATS an awesome idea. Esp the ON/OFF switch
Old Mar 18, 2008 | 05:47 PM
  #215
I like the sound of this! I can't wait for this to be finalized for release.
Old Mar 18, 2008 | 06:37 PM
  #216
shunderwunder's Avatar
Thats bad a$$. Now I really want an AEM EMS.
Old Mar 18, 2008 | 06:47 PM
  #217
Indy Evo's Avatar
Contact Buschur he will have (10) Version 1's at the end of this week.
Old Mar 18, 2008 | 07:25 PM
  #218
With the AEM setup, would I want Version 1 or Version 2? Would there be any advantages of running version 2 with an AEM? Thanks.
Old Mar 18, 2008 | 07:26 PM
  #219
CO_VR4's Avatar
Originally Posted by lexat20
Now if you could just make a contraption that will shift 1-2 2-3 and 3-4 perfect everytime.
Already built. It's called a sequential shifter.
Old Mar 18, 2008 | 07:49 PM
  #220
CO_VR4's Avatar
Originally Posted by davidbuschur
gsnt, you are being fooled with the video. In the video the unit was not working correctly. The clutch pedal does NOT stay to the floor. This is why you think it is illegal. The clutch pedal is actually pushed to the floor and the button is then depressed. When it comes time to launch you simply pop the clutch as quickly as possible, so it is foot operated. This is simply a valve to keep the clutch from releasing to quickly or to slowly. So it is in fact 100% legal.
The difference between this and the factory restrictor is the factory restrictor is in effect 100% of the time. So each gear change there is some restriction taking place. This only works when you want it to on the launch, not on each gear change.
Two questions, Dave:
1. When will version 2 be done?, and
2. Would you compare the effects of this setup with the action of the Tilton clutch valve that they advertise as doing something similar in terms of cushioning the clutch release?
Thanks...
Old Mar 18, 2008 | 09:05 PM
  #221
tabio42's Avatar
Hmm I don't know how the version 2 normally (without ECU help) knows when to stop working. The version 2 has the benefit of not needing to use your foot after pressing in the clutch I gather. But when you release the button to dump the clutch, do you have to do something else to make it stop working for second gear?
But to answer your question directly - it is a matter of personal preference. With the EMS you will have the same functionality with both. That is, the computer can still turn the launch aide off at a certain preset point. So if you want to dump the clutch by foot you get version 1. If you want to dump the clutch by pressing/releasing a button you get version 2.
Shunderwunder - I am sure Dave Buschur would be happy to sell you an EMS (and tune it) along with your launch aide
Old Mar 19, 2008 | 02:17 AM
  #222
Indy Evo's Avatar
Version 2 is done and will be tested in a very well known Evo soon. My component differs from the Tilton in the fact it can be adjusted without the valve being disassembled and a re bleed, and after the clutch is released all the fluid is returned like normal ie. not thru the valve for all the remaining shifts. This valve is adjustable from no flow to 100% flow. Version 2 would still be launched by a switch and controled by the AEM. If you have a standard ecu you would need two buttons one momentary for launch and another, on off push type to disable the slip circut. Thanks
Old Mar 19, 2008 | 06:41 AM
  #223
apeximprt2nr's Avatar
Price???
Old Mar 19, 2008 | 06:49 AM
  #224
Indy Evo's Avatar
Please contact Buschur Racing or ICS their numbers are in the first page of the thread. ICS is close by and they can handle the install as they have done U2SLO's
Old Mar 19, 2008 | 08:34 AM
  #225
turboDan's Avatar
Seeing that Version 2 will more than likely be used by the TRUE RACERS,not the test and tune,get my bragging rights TIMESLIP for the internet weekend warriors,then the AEM will most likely be the ECU of choice. How about this for an added "option" for Version 2? Incorperate a "line lock" as well,off the same TRANS BRAKE button used to activate the Launch Solenoid so that once the PRE-STAGE light is lit you roll into the stage beam,press clutch to floor,press the "Launch Button" which in turn also activates your "line lock" so that when you get vehicle up on the 2-step it will NEVER roll through the beams and when light drops you let go of button,which in turn activates clutch and releases line lock,consistant launches every time....also you get pretty much same roll out as well as your car will NOT move once it is activated? Sounds like a version 2a will be available soon if enough interest is made to move forward
