Boost Question
Old Mar 13, 2008 | 12:34 AM
1NastyMR's Avatar
Boost Question
Is it ok to run 25 lbs of boost falling off to 20lbs near redline on a stock turbo pump gas with full bolt ons if the A/F is proper? My A/F reads 11.4-11.6 and at higher RPM about 5800-7000 it goes to 12.2-12.4 is that bad or?? Would i need race gas to run that type of boost?
Old Mar 13, 2008 | 12:40 AM
chaotichoax's Avatar
WOT at high rpm you want the afr to taper not increase
12 and above is knock territory
you need to run a high octane to do that safely if those are accurate afr readings
Old Mar 13, 2008 | 01:00 AM
1NastyMR's Avatar
So I pretty much need a retune and if i get tuned for 11.w/e A/F that will be safe and should make more power?
