WOT-- always 7.35 on the wideband
what does it say at idle and cruising? if it says 14.7, then i bet you have a massive boost leak/improperly scaled injectors or the sensor is bad. if it reads very rich at idle or cruise then kreionic is correct, the calibration is wrong on the wideband most likely.
Wow i got it, i dint disconnect the o2 when i calibrated so i did one more time and everything it awesome running just like it suppose to.
Thanks for all your help it was calibrations all along
