Drop in pistons, to do or not to do “that’s the question”??
I am only here because I was sent a PM and asked to come.
If you have an EVO and want to make 500+ whp reliably or run over 8,000 rpm reliably you are going to need to to upgrade the pistons/rods.
The best way to do this of course would be to also build the cylinder head and have it properly ported. Pull the engine and build it too. We are one of the lowest price shops for doing this. Parts, labor and new short block will cost you $5600 if all that is done is the shortblock, parts and labor. Add another $1600 for our Stage 3 head.
Now, if your EVO has fairly low mileage we have done I-don't-know-how-many drop in piston builds. We were the first to offer this for the EVO's and we have pistons that are specifically machined to drop in the stock bores of the EVO's. If you did this job with us the parts/labor would run you about $2500. I have a high end professional hone from Mac. I've had it for 10+ years. It is not a simply ball hone or a spring type hone like TTP showed (not knocking anyone's hone). The hone we use will actually straighten out a cylinder bore. The problem is if the cylinder bore is that bad the engine needs to come out. I bore gauge the cylinders when we do drop in pistons and make sure that the build will be within spec. I've done drop in pistons up to 70,000 miles, that is the highest mileage car I've ever done it on. That car is still running strong at 550 whp and has been done for over 2 years.
In my opinion the only down side to the drop in pistons is still having the balance shafts in the engine, that's it.
That is what is needed to remove the front engine motor mount so the motor can be dropped down low enough to remove the frontcase and access the bshafts.
I used this method on my personal Galant VR4 years ago. Definately not a fun job, but doable.
Is it called a 19mm ratchet?
I understand removing them to hone but why replace? Do they go bad, are they not reusable once removed? I am not being sarcastic i am genuinely interested.
Actually I disagree on having to take the oil jets out. The type of hone that TTP is using would hit them and could bend them, I can see taking them out for that reason. The hone I have has a smooth plate on the bottom and can be run right down on top of the jet and it won't effect it. Also if you look the rings do not ride that far down in the cylinder so honing it that far down for a good ring seal isn't needed.
DB has a point though, but I like having the same finish on the whole cylinder.
i did drop in wiseco pistons, eagle rods and clevite bearing and everything is good 1000 miles in. about to do the 3rd oil change and going to full synthetic. made 504whp with it so far.
Now, if your EVO has fairly low mileage we have done I-don't-know-how-many drop in piston builds. I have a high end professional hone from Mac. I've had it for 10+ years. It is not a simply ball hone or a spring type hone like TTP showed (not knocking anyone's hone). The hone we use will actually straighten out a cylinder bore. The problem is if the cylinder bore is that bad the engine needs to come out. I bore gauge the cylinders when we do drop in pistons and make sure that the build will be within spec. I've done drop in pistons up to 70,000 miles, that is the highest mileage car I've ever done it on. That car is still running strong at 550 whp and has been done for over 2 years.
So, we could assume everything is right, but without the right tools your truely guessing and asking the customer to do so as well.
In my opinion, it should also be understood, that checking the static compression is not always a good indiactor of how a engine is sealing. You need to perform a leakdown to really guage that.
I guess we cannot argue with the success of the drop-in piston performances from everyone who has chimmed in..but everyone agreed it is not the right way to do it, just the most short term economical way. But, I guess sometimes it's not what's right, it's what is. Sure it will run, and make power..but I personally would never tell my customer it is a good idea, nor would I do it myself and be able to sleep at night without using my $2500 dial bore guage...but I am also a perfectionist and do everything in that manner.
One good thing about it is, if it going to be off, it's most likely going to be big..and there is a saying in engine building, " too loose you know it...too tight everyone knows it! "
