Drop in pistons, to do or not to do “that’s the question”??
Old Nov 27, 2008 | 01:04 PM
  #91
whitey4d's Avatar
Yeah I did. I thought you meant to use new factory rings with out rehoning the block.
To me it wouldnt make any sense reuse old rings on a new piston especially since the rings have to be expanded to get them off the old pistons.
Old Nov 29, 2008 | 09:36 AM
  #92
HeadGames's Avatar
Originally Posted by crcain
Uhhhmmmmm
I can't remember but I think my bad *** "summit" bore guage cost me like $100 or something around there. It's always appeared to be spot on when I use a mic to calibrate and test it. What does a $2500 bore guage do?
I don't know of any dial bore gauge that is "badass" for $100..but if it does the job!
Seriously, I am not familiar with the Summit gauge, but the Sunnen gauge is almost the industry standard, and with the setting fixture(not the mic method) it comes in around 2500..I think the gauge itself is $1200 or something stupid like that, for the one that measures in tenths. There is also one that measures in half thousandths that is probably less expensive. I imagine it's kinda like the difference in buying the walmart cheap tools VS Snap-On..they could both have a 13mm wrench, but the subtle differences make it worth owning the Snap-On and paying dearly for it, if it's what you do for a living.
Old Apr 11, 2009 | 04:32 PM
  #93
E85evo8's Avatar
good thread...subscribing so I can find this at a later date
Old Apr 22, 2009 | 12:05 PM
  #94
E85evo8's Avatar
just built the motor with Manley rods and Wiseco pistons..posted up a new thread w/pics in this forum
Old May 5, 2009 | 06:36 PM
  #95
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Wow that was a good read. I'm still on the fence right now between Buschur Drop ins or Buschur Stage 3 block. I just have to sit down and speak with Jimmy @ The Shop but so far this has been a very good read.
Old May 5, 2009 | 06:47 PM
  #96
kouzman's Avatar
Jimmy has built many cars. He will do my drop-in too. And all the cars perform no problem and there is a trend lately on many 130mph street monsters...
Old May 6, 2009 | 03:20 AM
  #97
DBallz's Avatar
Let me know when you drop in setup is completed I would like to get your personal opinion on it once you have the car all bolted up and tuned. I opted out because I need to upgrade my brakes and my tires but I think I will get this done maybe in the fall
Old May 6, 2009 | 07:52 AM
  #98
TTP Engineering's Avatar
Oh, they will do 130mph after you're done... A few times, that is.
Old May 6, 2009 | 08:27 AM
  #99
David Buschur's Avatar
We've done drop in pistons here in atleast 50 different EVO's, never had a problem doing it.
Not sure what's with the latest hype of it not working well.
Old May 7, 2009 | 11:54 AM
  #100
DBallz's Avatar
Heh DB what is the most HP you have ever seen on your dyno from a drop in setup. Just a round about #.
Old May 7, 2009 | 12:17 PM
  #101
kouzman's Avatar
Are you suggesting that after a... few times they will not perform? If yes then allow me to disagree... If it gets done correctly and knowing the limitations of such setup then it can take you a long way...
DB seems to agree and I see cars with his piston/rod combo perform very well...
Personally I stand by my selection to go with a drop-in simply because my personal experience and proof that I have seen with my own eyes is enough...
Old May 7, 2009 | 12:44 PM
  #102
We've made close to 600 whp on the drop in pistons/rods. You have to consider the fact that most guys doing pistons/rods are doing it to keep from doing the entire engine build because of finances. These same guys are not after 600+ whp but trying to keep their 400-500 whp builds from breaking a rod and then really being out a lot of money.
You can come to us and have drop in pistons/rods done for about $2600 parts and labor. The pistons/rods themselves are good for huge power, say 1,000+.
If you do a Stage 3 shortblock we use the same pistons/rods and the cost to do the shortblock is about $6100. That is parts/labor etc.
That is a lot of difference to a guy on a budget.
If that guy on a budget didn't do rods and pistons and his rod let's go he is going to be out the $6100 plus a block and more than likely a crank too, total price $8650.
We have done a lot of drop in pistons/rods and I can not honestly think of a single engine that had a problem, not one. We have pushed the tolerances on the pistons on a few builds by the customers choice knowing the pistons would slap when the engine was cold but even those have run strong and not broken.
My brothers daily driver is driven at 30+ psi of boost on a stock EVO8 turbo every single day of the week 365 days a year. The engine sounds like a diesel when it starts because the piston to wall clearance is lose, uses no excessive oil, made the most power on a stock turbo we have seen (375 whp on our dyno) and has run 11.5's. He has driven it for over 2 years in that state of tune and build.
I would, of course, rather do an entire build but there is absolutely nothing wrong with doing pistons/rods.
Old May 7, 2009 | 12:54 PM
  #103
Wicked E's Avatar
David-
Thank you for supplying the pistons/rods to Mike @ AWD. Just got them over nighted UPS.
Also, thank you for re-assuring me that I was taking the right path both monetarily and safety-wise.
See you at the Shoot-Out!!
-E
Old May 7, 2009 | 01:47 PM
  #104
E85evo8's Avatar
I too fall into that 600whp club with drop in pistons and rods...If done correctly and carefully there shouldn't be a problem. My motor has 10K original miles on it and is in brand new shape....I have a thread posted up so everyone can see that this is a viable solution for people on a budget. I'm using Manley H-beams and Wiseco pistons..just some FYI
Old May 18, 2009 | 12:47 PM
  #105
ssteve's Avatar
anyone make higher compression drop in pistons? Like 9.5:1? My motor only has about 8k on it so I'm considering some pistons/rods but would like to do a strickly e85 build and add some compression.
