Evo II & III tranny gear part #s
Old Mar 20, 2008 | 10:51 AM
JUANPSI's Avatar
I was just going to change the ring gear on the diff. On the caps I can't get it to open the file.
Old Mar 20, 2008 | 11:18 AM
Kristopher's Avatar
Are you going to keep the LSD then? The CV axle is too short to use the Evo LSD.
I kept my stock front diff. Makes it easy to use a DSM trans if I ever had to go back. Also, do the gearing calcs with a DSM final drive and Evo 5th gear.
Sorry, don't know what to tell you about the CAPS - that's the same one I had used.
Old Mar 20, 2008 | 08:27 PM
94AWDcoupe's Avatar
the evo final drive is 3.909
dsm final drive is 3.54
you are correct in needing to swap a 3.54 ring and pinion into the evo 2 box to make it work with your 3.54 rear pumpkin. problem with that is it would only work with non-lsd evo box. the factory lsd is larger than a dsm diff. the ring gears wont swap.
Old Mar 21, 2008 | 01:25 PM
JUANPSI's Avatar
Well there goes that idea ^. I'm still trying to get the caps to work. I got it open but it won't find any info. Thanx for all the help guys. I'll try calling rre.
Juan
Old Mar 27, 2008 | 12:07 PM
JUANPSI's Avatar
Just called tre. The gears are not the same and they do not recomend modifying them for double synchro. Anyone have a evo 3 tranny 4sale????
MisUnderStood
Jan 27, 2017 10:11 AM
av00va
Sep 14, 2014 04:19 PM
EVO_RYAN
Jan 16, 2010 09:05 PM
panem
Nov 17, 2009 10:19 AM
TurbotrixRacing
Turbotrix Racing - Edison, NJ
45
Dec 11, 2005 05:25 AM
