Help identify these injectors
I recently purchased a set of injectors from another message board. They were used in a DSM. However, when I went to install them, they looked a little different than the stock injectors. I don't want to install them if they aren't the right ones. These are supposed to be PTE 780s.
Numbers on the top of the injector: 6154 17113742
Inscribed on the side: 19363/5 834
I'll post a pic in a few minutes.
Rochester (PTE injectors)
17113738 - 50 lb/hr
17113741 - 55 lb/hr
17113814 - 65 lb/hr
17113742 - 75 lb/hr
17113743 - 85 lb/hr
17113744 - 95 lb/hr
Lbs/Hr to CC formula = (lbs/hr) * 10.5
17113738 - 525cc
17113741 - 577cc
17113814 - 682cc
17113742 - 787cc
17113743 - 892cc
17113744 - 997cc
17113738 - 50 lb/hr
17113741 - 55 lb/hr
17113814 - 65 lb/hr
17113742 - 75 lb/hr
17113743 - 85 lb/hr
17113744 - 95 lb/hr
17113738 - 525cc
17113741 - 577cc
17113814 - 682cc
17113742 - 787cc
17113743 - 892cc
17113744 - 997cc
The part of the injector that goes in the intake is different. It seems like they are a little long overall. Like the fuel rail wouldn't bolt down all the way.
Thanks for the help BTW. Much appreciated.
This distance appears to be larger than the stock injectors. Can someone measure the stock injectors? I had to put mine back in the car until I can get to the bottom of this subject.
Inprogress
17
Mar 2, 2008 01:42 PM
