Head skin is it ok?
Old Mar 17, 2008 | 05:24 AM
extremier's Avatar
Head skin is it ok?
After I experienced coolant waste from a bad head gasket, i did:
Changed the head gasket ( cometic), and Head studd ARP...
But the shop that this this work also got the HEAD SKINED to be sure its ok...
question: Will this cause significant compression rate increase ?
Will this be a problem?What is the solution?
Thanks a lot for all the inputs...
PS. I do run FP green and 272 cams...
Old Mar 17, 2008 | 05:35 AM
finallyevo's Avatar
No it will not change your compression. Typically they only deck the head a few thousands of an inch. This is very minor and you will not see any significant change in compression.
P.S. if you ever blow another head gasket I would recommend just replacing it with another OEM unit. Typically, they seem to work best.
Old Mar 17, 2008 | 05:57 AM
sekula's Avatar
cometic did very poorly in a test against an oem headgasket...just stick with oem!
Old Mar 17, 2008 | 06:14 AM
TTP Engineering's Avatar
If you are using a cometic, be prepared to do this job all over again.
COMETIC is garbage.
Old Mar 17, 2008 | 08:23 AM
SWOLN's Avatar
+1 I think Cosworth won out on that comparison. Who knew?
Old Mar 17, 2008 | 08:39 AM
05graphiteMR's Avatar
i am using the HKS head gasket. when we were building the engine, we first got a cometic, had used them before on hondas with good results. when the cometic showed up we were pretty disappointed so i shelled out the extra for the hks
luislm21
Jun 3, 2013 12:55 AM
konstantinosIX
Feb 10, 2011 07:34 AM
extremier
Dec 3, 2009 07:58 PM
swift_dsm
13
Jul 6, 2009 09:35 PM
goucho
Nov 19, 2007 01:34 PM
