Help, wrong head gasket
Old Jun 1, 2013 | 06:23 PM
luislm21's Avatar
i bored my engine .40, and for mistake i bought 85mm head gasket...
can i use the 85mm head gasket>>??
Old Jun 1, 2013 | 06:27 PM
joseph143's Avatar
your bore is now 86mm and you are asking if you can run an 85mm?
the answer is no...
Old Jun 1, 2013 | 06:31 PM
luislm21's Avatar
im asking because i was using stock headgasket, and now ill change it for a cometic.. the 85mm head gasket really doesnt have 85mm, it has about 87mm...
Old Jun 1, 2013 | 06:32 PM
luislm21's Avatar
after engine rebuild, i used OEM head gasket
Old Jun 1, 2013 | 06:41 PM
CeeWhizzle's Avatar
wat... The bore on the OEM head gasket would be smaller..
Old Jun 1, 2013 | 06:44 PM
luislm21's Avatar
after rebulid i used old OEM headgasket, and there was no problem. but i wanted to change the old head gasket to a New head gasket, but i purchased Cometic 85mm head gasket.
Old Jun 1, 2013 | 07:09 PM
superbovine's Avatar
You rebuilt an engine then put the used head gasket back on?
Old Jun 1, 2013 | 07:12 PM
luislm21's Avatar
yes, i put the used head gasket back.....there was no problem
Old Jun 1, 2013 | 08:31 PM
Ok, just clarifying.
Old Jun 2, 2013 | 08:40 AM
luislm21's Avatar
so, no im using Cometic Head gasket, and i forgot to buy the 86mm one,i bought 85mm one
Old Jun 2, 2013 | 09:19 AM
CeeWhizzle's Avatar
...Then buy an 86mm one... I'm almost certain Cometic has to be the same size as the bore
Old Jun 2, 2013 | 02:17 PM
luislm21's Avatar
i purchased 85mm one, so i want to know if i can install it
Old Jun 3, 2013 | 12:42 AM
17pstockcar's Avatar
no
Old Jun 3, 2013 | 12:55 AM
CN9Adaiski's Avatar
Dont use it.
Use the one thats the right size for your motor.
nomnom
May 30, 2017 05:58 PM
DIDYSIS
18
Feb 24, 2013 10:14 AM
ezz-e
30
Sep 2, 2012 12:06 AM
Piro Fyre
Dec 8, 2011 07:37 PM
App420
Jan 27, 2007 11:02 PM
