Changing drivetrain fluid made easy!
Old Mar 23, 2008 | 05:35 PM
ak47po's Avatar
I found this pump to change my fluids and it works like a dream.The best thing is you can measure the amount to of fluid pump so you don't have a bunch of new fluid ending up all over everything and wasting it,best thing is it's only $15.00.
http://www.harborfreight.com/cpi/cta...emnumber=93477
Old Mar 23, 2008 | 05:41 PM
Paul Nelson's Avatar
Ive got lots of harbor freight tools laying around. I wonder how much i would actually use it
Old Mar 23, 2008 | 05:44 PM
ak47po's Avatar
It's better than a funnel and hose.
Old Mar 23, 2008 | 05:56 PM
beastlytalon's Avatar
Mine was useless, unless you can weld. I purchased it thinking it would be the greatest thing. However the one I had, the pump and hose had to be changed from each end to use (L). The problem is that there is a hose on the cap so when I changed ends, it obviously wouldn't seal and would just leak out. Maybe mine was made incorrectly.
Old Mar 23, 2008 | 06:12 PM
6-speed's Avatar
Seriously I use a turkey baster to change the rear diff fluid; works like a dream.
The t-case fluid is easy to change with some vinyl tubing you can pick up at any Home Depot and a decent funnel (as per the Evomoto DIY).
It also helps that I don't have the stock airbox and undertray in the way either.
Old Mar 23, 2008 | 06:14 PM
EvoooB's Avatar
for the tranny and tcase i just use some clear tubing and a funnel. it couldnt have gone easier, no pumping or anything involved. just measure out the correct amount and pour in. the rear diff i used a similar pump
Old Mar 23, 2008 | 06:20 PM
Curt@MrLed's Avatar
Former Vendor
Dammit for as much as I am in that place I never saw that. Thanks.
Old Mar 23, 2008 | 06:24 PM
Exciting News's Avatar
That's similar to what I use. Of course, mine was from Autozone, solid, and cost $6. These pumps are great.
Old Mar 23, 2008 | 06:50 PM
ekizenbe's Avatar
im buying one tomorrow
Old Mar 23, 2008 | 06:52 PM
apagan01's Avatar
thats what i needed today on my rear diff change,,,, i even have a HBR freight store close by ,,,,,, darnnnn!!!!
Old Mar 24, 2008 | 05:28 PM
jmoudry's Avatar
I wish I had one of those a week ago. I will be ordering 2.
Old Mar 24, 2008 | 06:03 PM
ENVY-THIS's Avatar
thanks gonna go get one now, changing out the rear diff was a pain in the butt....this will be alot easier....
Old Mar 24, 2008 | 11:37 PM
Jackyll's Avatar
I'm planning on doing this once it gets warmer outside, but do I need any special tools? I'm doing the trans, t-case, and rear diff. I thought I read somewhere in a write up that I can't seem to find right now that I'd need a 25mm or 26mm socket for the rear diff or something like that. I think my socket set goes up to 22mm... basically what size sockets do I need to have to drain and fill all 3?
Thanks
Old Mar 25, 2008 | 06:01 AM
schred86's Avatar
amsoil sells a nice pump that goes into any quart or gallon of oil
heres my thread with some pics of it
https://www.evolutionm.net/forums/sh...d.php?t=304335
Old Mar 25, 2008 | 06:33 AM
deadbeatrec's Avatar
i have one like that and when i did my diff's it was easty. but mine wouldnt suck up the thick *** fluid so i had to take out the plunger and pour it in.
