Cut up my stock UICP
Old Mar 25, 2008 | 07:43 PM
EvolNinja's Avatar
This is either a dumb or bright idea. Anyways, I wanted a bigger end for the LICP so I decided to cut one section of the UICP and connect it to the Injen LICP. Haven't install it yet but you guys tell me if my idea is either or . Will post some pic once it uploaded to photobucket.
Old Mar 25, 2008 | 07:46 PM
kreionic's Avatar
i dont have the slightest idea on what your talking about
Old Mar 25, 2008 | 07:49 PM
idriveanevo's Avatar
+1
Old Mar 25, 2008 | 07:51 PM
EvolNinja's Avatar
Ok here are a few pic to show you what I'm talking about:
This pic is the Injen LICP that I cut the smaller end pipe and connect the middle section of one of the UICP.
This pic is my cut up OEM UICP.
and this pic is my fabrication of the Injen LICP with bigger end.
Old Mar 25, 2008 | 07:57 PM
EvolNinja's Avatar
The sad thing is... I'll have to buy that section if I ever need to go back to stock
Anyways, here's a pic of my Evo in the nice little road up the hill. There's two nice turns but I dare not try to drift there. I don't want to see my car wrap around the trees.
Old Mar 25, 2008 | 08:26 PM
EVO8emUp's Avatar
Well, since there is no bead on the pipe, keep enough tools in your car to put it back together if the coupler blows off. Other than that, you should be good to go.
Old Mar 25, 2008 | 08:27 PM
EvolNinja's Avatar
Isn't it possible to put bead on the new section?
Old Mar 25, 2008 | 08:30 PM
Nissan2Evo's Avatar
Old Mar 25, 2008 | 08:38 PM
golruss's Avatar
Check out E-Bay,
Bead roll roller - NEW- kit
I bought one and used it today.
goodluck.
Old Mar 25, 2008 | 09:03 PM
EvolNinja's Avatar
Thanks golruss I'll check it out.
Old Mar 25, 2008 | 09:15 PM
EvolNinja's Avatar
Golruss, it's rather expensive than I thought. Boy, if you live close, I'll come over and have you do it for me.
Old Mar 26, 2008 | 06:54 AM
EvoDom's Avatar
i dont even no how u would think of someting like this....whats the point??
Old Mar 26, 2008 | 07:04 AM
Hendrix's Avatar
Guaranteed that LICP will blow apart the first time you boost.
Old Mar 26, 2008 | 07:17 AM
philevo's Avatar
I see why you did it, the larger diameter pipe right? The kit was designed that way for a reason, just try it. If you dont bead the pipes they will blow off every time you get into boost.
Old Mar 26, 2008 | 01:16 PM
EvolNinja's Avatar
Yes the point is to increase the diameter of the inflow of hot air to the IC. I will be using T-bolt clamps and hopefully find a place to do the bead for the pipes. Do you guys know if there's any local shop that will do it?
