Cosworth 272's
Old Mar 26, 2008 | 04:59 PM
Evo818's Avatar
Cosworth 272's
i got them in my car after 3 months of driving i got a tick the last night its in shop now but any one know what it might be i think its valve or spring and retainer it ticks faster when you give it some gas... any help thanks
Old Mar 27, 2008 | 04:52 PM
Evo818's Avatar
any one got any advice shop thinks its a rocker arm but they dont know for sure i dont want to buy something its not any one....... i got 272 cosworth cams on stock valve terain they said it woud run fine no problem if any one has any help let me know please thanks
Old Mar 27, 2008 | 04:56 PM
EVIL_EVO_VIII's Avatar
The tick maybe the lifters...
Old Mar 27, 2008 | 04:58 PM
Psquared's Avatar
^^ +1 Not bleeding the lifters is notorious for causing a ticking sound.
Old Mar 28, 2008 | 07:34 PM
Evo818's Avatar
the shop that did it is dyno comp here in az they said you dont have to bleed lifters if your not changing them but dont you have to do it any ways cause you installed bigger cams
Old Mar 28, 2008 | 07:40 PM
SuPeRNeT's Avatar
Theres your answer..
Old Mar 28, 2008 | 07:45 PM
Evo818's Avatar
ok so definantly need to tell them to do that thye said it sounds like a rocker arm so i will tell them to bleed first thanks guys
Wicked E's Avatar
Find a new shop...
-E
Old Mar 28, 2008 | 07:57 PM
Burklow's Avatar
Originally Posted by Wicked E
Find a new shop...
-E
I agree. Bleeding the lifters is a basic MUST for any cam install. It isn't even very difficult to do. They should know better.
Old Apr 7, 2008 | 09:11 PM
Evo818's Avatar
so i got my car back today after paying 400 for lifters and install and that wasnt the tick they are now telling me its a bearing or piston pin its loud and when you rev it gets louder
Old Apr 8, 2008 | 01:12 PM
Boost_Inspired's Avatar
hnmm did u double check to make sure the new lifters were properly bled , if the noise started right after cams its gotta be a valvetrain issue.
Old Apr 8, 2008 | 01:18 PM
mdsevo06's Avatar
$400 FOR LIFTERS! You could have purchased a new set of JAM 3mm for $175. Need to find a new shop and have it looked at....Vivid maybe.
Old Apr 8, 2008 | 01:35 PM
SLO-EVO's Avatar
99% chance it is your lifters
Old Apr 8, 2008 | 01:39 PM
Magnumpsi's Avatar
That does not sound right. If you want PM me and I am sure we can figure it out for you.
Thanks,
Mitch M
Old Apr 8, 2008 | 02:12 PM
Evo818's Avatar
the 400 was labor and lifters lifters were 150 the total price after lifters and labor was 400
