boost question
Old Mar 30, 2008 | 12:48 PM
1 WICKED EVO's Avatar
boost question
i just intalled hks 280's. my vacuum use to read 16 to 17 now that i out the cams in it around 10 is that normal?
Old Mar 30, 2008 | 01:10 PM
Precision's Avatar
Yes, when you go to a set of cams with a lower centerline and more overlap the motor will make less vacuum at idle. It is compleatly normal, now you just need to get tuned.
Old Mar 30, 2008 | 01:13 PM
ApacheFixer's Avatar
^ +1
Old Mar 30, 2008 | 01:17 PM
diiirk@AwdMotorsports's Avatar
I went from 18 vac to 16 at idle after the tomei cams.
Old Mar 30, 2008 | 01:31 PM
CBRicahrd's Avatar
the poor vaccum is what gives the motor the "lumpy" sound everyone always loves so much.
Old Mar 30, 2008 | 01:37 PM
fugiwara's Avatar
yes it's normal, and I heard that losing vacuum might hurt braking performance if you brake in neutral, leave in the gear will be ok.
Old Mar 30, 2008 | 01:39 PM
fugiwara's Avatar
btw, your title should be "loosing vacuum" not "boost question", it has nothing to do with boost.
Old Mar 30, 2008 | 02:07 PM
psphinx81's Avatar
totally normal
Old Mar 30, 2008 | 08:08 PM
thanks guys!!
Old Mar 30, 2008 | 08:18 PM
sparky's Avatar
I have HKS 280/272 and mine will idle at -9 or -10. With adjustable cam gears you can dial in a smoother idle. I imagine that your cams are installed straight up. If you were to retard the cam timing you could achieve a smoother idle.
MalibuJack
May 25, 2017 06:46 PM
MitsQueen
Aug 20, 2002 12:30 PM
